Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-20-2020, 12:54 PM   #1
dan s
dan s's Avatar
Help, where to stop? Roof skin replacement
Hello gentlemen just looking for some advice on roof skin replacement. Should I just sandblast what you see in the pictures? Or do you think I should separate all of these panels to get the surface rust from between them? Anybody out there with experience just cleaning up what I can see then epoxy prime, panel bond skin and then self leveling seam sealer in the gutter. Obviously this doesn't have to last forever but I don't want to see it bubbling in a couple years either. Any help would be greatly appreciated thanks Dan.
dan s is offline   Reply With Quote
Old 12-20-2020, 03:22 PM   #2
ApacheNick
Re: Help, where to stop? Roof skin replacement
I would clean up everything you can without cutting the cab apart and epoxy.
For inside of the window posts and other similar places I would use something along the lines of eastwood's internal frame coating because it has the long (2ft) spray tube. It may not be perfect but it's better than doing nothing.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 12-22-2020, 11:40 AM   #3
LT1 Burb
LT1 Burb's Avatar
Just wire wheel where you can, spray rust prep in there and then Por 15 it, just keep paint away from where you are going to reweld. Also a good time to insulate both skin and cab.
LT1 Burb is offline   Reply With Quote
Thread Tools
Display Modes
