Old 12-11-2018, 09:57 PM   #1
Uglykato
Help identify C20 rear end
How is everyone? First post other than the welcome intro. So, the guy I bought this truck off told me the rear end will eventually need replaced; it makes a noise when you drive. It doesn’t affect the drivability, I’d just like to get it replaced. I did a fair amount of reading on the different rear ends in these trucks and am unsure what I have. I don’t want to pull the cover off just to count the gears and look for the stamp. Some people on here seemed savvy enough to identify it with the cover still on. I’d love to hear what you think it is.
Uglykato is offline   Reply With Quote
Old 12-11-2018, 10:00 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Help identify C20 rear end
A year might be helpful.
Old 12-11-2018, 10:00 PM   #3
sweetk30
sweetk30's Avatar
eaton h.o. series axle by the looks of it . grandfather to the corp 14 bolt full floater and share some parts swapability backwards .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-11-2018, 10:01 PM   #4
mongocanfly
mongocanfly's Avatar
Welcome.....
Eaton ho52...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-11-2018, 10:05 PM   #5
Uglykato
1967, 10 bolt rear. I am just looking for a direct bolt in replacement.
Old 12-11-2018, 10:25 PM   #6
Uglykato
Originally Posted by mongocanfly View Post
Welcome.....
Eaton ho52...
What gear ratios would work? Not sure how many were made in the HO52.
Old 12-11-2018, 10:42 PM   #7
sweetk30
sweetk30's Avatar
that might have 10 bolts on the cover but do NOT mix it up with a 10 bolt gm style rear axle . 2 different units by far and wide .
sad part is almost nothing for the eaton ho axle family anymore . there stock i heard rare 3.73 most were 4.56 or some 4.10 and some rear 5.12 or 5.13 i think .
if you want newer better options and still 8 bolt if that what you have find a 14ff from the 70'-90's trucks vintage and weld on new spring perches and shock mounts .
or if you want disc brake rear later find a 00's up rear with factory disc brake and swap that and be done minus metric lug nut threads on the studs .
Old 12-11-2018, 11:32 PM   #8
Uglykato
I would like to swap to disc eventually down the line. Sounds like I should just wait till the rear quits completely or when I have time to do a big project and swap the axles to something newer. Thank for the feedback all.
Old 12-12-2018, 12:23 AM   #9
Captainfab
60-66 Nut
The most common gear ratio I have found in the Eaton H)52/72's is 4.57. There was a 4.10 option, but I have seen only a couple of those. I would not put any money into that differential. I would also recommend looking for a 10.5" 14 bolt. I do make trailing arm mounts specifically for the 14 bolt, when the time comes that you need some.
Old 12-12-2018, 12:33 AM   #10
Uglykato
Thanks, I did see your name in a different thread speaking about rear ends. I guess I’ll do my due diligence and research swaps when the time comes. I think for now I am going to leave as is and work on other things and do some research on what works. I’ll look into the 10.5”, 14 bolt swap.
