Old 04-14-2002, 09:16 PM   #1
Low69CST
Post Wiring Help Needed
I'm putting in my painless wiring harness. I noticed the splice that it has for the nuetral saftey switch. the wire that goes from the fuse box to the switch is purple. I know I am supposed to splice into this and run to the nuetral switch, but it looks like there are 4 prongs on the switch, which and what plugs into all these spots. Also, for the switch for the brake pedal, there are 2 prongs for the orange and white wire, does it matter which prong each wire goes to?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims
Not my daily driver. More like my weekend A$$ KICKER.
See my truck at: http://www.geocities.com/low69cst/
Future Automotive Engineer attending the University of Kentucky.
Feel free to message me on AOL, SN- SS95ZQ8
My Dad's projects:
72 Short Fleet 4x4 Chyenne Super
72 Long Fleet 4x4 Chyenne Super
Both 350 autos restored original
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-14-2002, 09:18 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
the brake light switch does not matter, I think there is only supposed to be 2 purple wires for the N safety switch, I know my truck is bypassed with only 2 wires joined into one.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-14-2002, 10:29 PM   #3
Als454
Post
I believe the other two terminals are for your reverse lights (automatic)
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
3" Exhaust W/Headers
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 04-14-2002, 10:51 PM   #4
cali_surfer
cali_surfer's Avatar
Post
Hey Low69..... that Painless kit isn't quite painless is it? I installed their kit on my '69 as well. The brake light switch doesnt matter which is orange or which is white. The neutral safety, I didn't have to deal with the stock switch *have a B&M Megashifter* so I couldnt tell you on that. If you have any other questions on the install I'd be glad to answer them for you.
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 04-14-2002, 11:42 PM   #5
Low69CST
Post
Als454, that makes sense about the back up lights. That would be the most sensable place to trigger the back up lights, also i have 2 wires labled "back up lights" that I don't know where they go. Thanks for the help. Anybody know which prongs on the switch are for which (N safety and back up lights)?
Cali Surfer-
I have a wire labled "Emergency brake". Is this used with our factory E-brakes and dashes or is this for using some later model with a E-brake warning light in the dash?
Thanks again
My Dad's projects:
Old 04-15-2002, 12:47 AM   #6
cali_surfer
Post
Yeah, when I saw that wire I was like "huhhh" because our trucks didn't have a parking brake light. I cut it and terminated it, i.e. not use it.
Old 04-15-2002, 03:56 AM   #7
OhioDan
OhioDan's Avatar
Post
According to the Detroit Iron Factory Shop Manual CD,(factory wiring schematic) the purple wire goes to the 2 connections that are side by side. Not the 2 that are angled and side by side. It also says that the DarkGreen and the LightGreen wires goes to the back-up lights. Hope this helps?
http://OhioDan.Freehomepage.Com
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
