03-09-2015, 12:52 PM | #1 |
Project Junkie! Fishing Poor!!
Original Blazer Gas Tank Fill Neck....
I am looking for an original 69-72 Blazer fill neck. The one attached to the gas tank itself. I am going to have the manufacturer of the steel tanks manufacture tanks with them attached so us Blazer owners stop having the fill neck issues with the reproductions that are out there now. Anyone have one or two?
I am also still looking for a complete original fill hose assembly (3 piece) so I can use it for a model to make a single piece molded fill hose. Anyone have one of those? Please let me know. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
03-09-2015, 01:34 PM | #2 |
Re: Original Blazer Gas Tank Fill Neck....
wes I have a fill pipe that you can make a reproduction of as long as i can get it back and a deal on a new one I am not that far along in my build on my 72 blazer so you are welcomr to use. Let me know thanks Richie
03-09-2015, 02:47 PM | #3 |
Which one are you talking about? There are 69-70 and then 71-72. The 69-70 starting from the filler nozzle, has the nozzle, then a rubber hose, then a bent steel pipe, and another rubber hose that hooks it up to the tank. I think that the 71-72 is a nozzle and fill pipe all in one piece with a short rubber hose between the end of the fill pipe and tank. WES
03-09-2015, 03:40 PM | #4 |
My 70 has a one-piece fill with the short straight hose from it to the tank, I think... I better take the cover off and look again.
I have 2 original Blazer tanks with the neck on them, I would be willing to give up one for the cause. One needs to be put on my repro tank... My repro tank with the crappy neck has been causing problems, making me have to run the gas pump at half-throttle to keep from spilling all over the side.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-09-2015, 05:10 PM | #5 |
OK, Let me know. I am just trying to make things better for us Blazer owners. WES
03-09-2015, 05:14 PM | #6 |
It'll be raining here until the weekend, I'll get it pulled then.
03-09-2015, 09:33 PM | #7 |
Wes my blazer is a 72 and fill nozzle and pipe is one piece
03-10-2015, 12:14 PM | #8 |
Would you mind posting a pic of your gas tank (the fill nozzle and pipe). I picked up an original tank, but not sure what year it is. and I have a 72 Blazer
Thanks, Mike
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
03-11-2015, 10:23 AM | #9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=648434 |
03-11-2015, 11:13 AM | #10 |
awe.. makes sense now. Thanks
03-11-2015, 07:17 PM | #11 |
When we get them made I am thinking that the fill pipe will work for Blazers from 69-71. WES
03-15-2015, 11:37 AM | #12 |
Wes, the tank I can cut the filler tube off is worse than I remembered so I will just cut the tank itself to include the filler tube and vent tube (green square). But, the vent tube is rusted off at about where the red arrow is. Will that still work for you? If so, please PM the shipping address to me.
03-15-2015, 12:11 PM | #13 |
This is what I have cut out. I was unaware that the vent tube went so far into the tank and was held to the top with a strap, so I cut that part out too.
03-18-2015, 09:38 PM | #14 |
This is boxed up ready to go. Do you still want it?
03-18-2015, 09:47 PM | #15 |
The burb ones are different as well. I might have one laying around that I removed.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-19-2015, 04:28 PM | #16 |
smbrouss70, PM Sent.
69-72, Let me know what you have. WES
03-19-2015, 05:12 PM | #17 |
I also need 1 or 2 of these so I can produce a single molded filler hose too. WES
03-24-2015, 06:34 PM | #18 |
I have a 70 parts Blazer with 2 piece and tank.
03-25-2015, 12:54 PM | #19 |
Got a picture? Have they been removed? The reason I ask is because I want things as they were originally so that when I have the molded single piece hose done it will fit without issues. How much do you want also? Let me know. WES
03-25-2015, 05:14 PM | #20 |
They are not removed so will be hard to get pic of both pieces.
03-27-2015, 12:48 PM | #21 |
OK. Well when you remove them take it loose from the tank neck and the upper filler nozzle. I don't need those pieces. I need the rubber hoses with the steel pipe in the middle in tact so I can use it to copy with a single piece hose. You can send everything if you like. What is the $$ WES
03-27-2015, 12:56 PM | #22 |
I have no idea what they go for make me a reasonable offer! And I have not been out to parts Blazer yet. I have a major deadline on my 69 build for car show so bare with me....Andy
09-28-2015, 09:39 PM | #23 |
Does anyone have a filler neck that connects to the gas tank for a 72 blazer. I have an aftermarket gas tank and need this to make the tank fit.
09-10-2016, 01:10 PM | #24 |
Any updates on these future products, Wes?
09-07-2017, 01:00 PM | #25 |
I see I'm a little late to the party, but I just wanted to weigh in and check if this has happened and are the molded tank inlet necks available?
I think that just being able to manufacture the tank inlet necks would be a huge boon, even if you can't get the tank manufacturers to incorporate them natively, some folks, like me, would be willing to buy them separate, because a previous owner of my truck got a new tank but didn't transfer the molded inlet tube, so I would really like to be able to get my hands on one, whether it can be attached to this tank or if I had to get another tank, just being able to get the molded neck would be awesome.
My toys: 1971 GMC Jimmy 2008 Hummer H3 Adventure 2003 HD Road King |
