09-14-2004, 03:17 AM | #1 |
Its Magically Delicious
Lower tailgate hinge
i have a fleetside ... where can i get new rubber for the lower tailgate hinge .. are they the same as the stepside lower hinge rubber or what ???...please help
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
09-14-2004, 12:22 PM | #2 |
Back from the Dead
I too am looking for the tailgate rubber bushings since mines been rattling around pretty good and driving me crazy!
Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
09-14-2004, 12:26 PM | #3 |
There are no rubber bushing in the tail gate trunions for a fleetside or stepside tailgate. They are metal to metal from the factory.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
09-14-2004, 01:06 PM | #4 |
here what im curious about .. this is from a truck shop catalog .... it shows that stepside have rubber .. im curious if you can use them on fleets as well ....something fits on the large hole of the trunnion ... im assuming its a rubber bushing
09-14-2004, 01:24 PM | #5 |
Stepside originals are cadmium plated steel. Looks like they made a poly version of it. Should be sweet for the stepside owners.
Haven't heard anything about poly versions for the fleetsides though.
09-14-2004, 01:31 PM | #6 |
The fleetside trunions are larger diameter than the stepside trunions.
fleet trunion is 1-9/16" outside diameter. step trunion is 1-5/16" OD. The stepside trunion will actually fit inside the fleet trunion. Both tailgates pivot on the outside of the trunion hinge.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. Last edited by 71Chev; 09-14-2004 at 01:43 PM. |
11-16-2014, 10:29 PM | #7 |
Re: Lower tailgate hinge
1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (2 Piece Set) made of Stainless Steel and Delrin.
These are replacement hinge trunnion parts to upgrade your chevy fleetside truck. These are perfect for the truck restorer! These are Very quite while opening and closing the tailgate. You have to reused your original Trunnion hinge plate/bracket as seen in the pictures. Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck. I recommend power coating or chrome your Trunnion hinge plate before installing these back on it. To prevent further rusting. See my attached link if your interested in purchasing" http://www.ebay.com/itm/171632939274...9#ht_517wt_974 I also offer a cheaper version, Made of all Stainless steel on this listing: http://www.ebay.com/itm/171632938635...9#ht_498wt_974 I also in the works on building 67-72 trunnion hinges. I'm shooting for the end of Feburary for the 1967-1972 trunnion hinges set. I will post as soon as I have them ready! Website is: http://tdtrunniondesign.com My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896 66 chevy truck Fleetside LS1 67 Camaro Convertible 327 Last edited by 1966chevy; 01-07-2015 at 12:54 PM. |
02-04-2015, 08:35 PM | #8 |
1967-1972 and 1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (6 Piece Set) made of Stainless Steel and Delrin. Now offering the complete SET!
These are replacement hinge trunnion parts to upgrade your chevy fleetside truck. These are perfect for the truck restorer! These are Very quite while opening and closing the tailgate. See my attached link if your interested in purchasing" http://www.ebay.com/itm/171709176937...#ht_559wt_1094 I also offer a cheaper version, Made of all Stainless steel on this listing: http://www.ebay.com/itm/171709178087...#ht_413wt_1094 SOLD OUT http://www.ebay.com/itm/171743832627...84.m1555.l2649 SOLD OUT I also in the works on building 67-72 trunnion hinges. http://www.ebay.com/itm/171709178881...#ht_430wt_1094 Website is: http://tdtrunniondesign.com My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896 66 chevy truck Fleetside LS1 67 Camaro Convertible 327 Last edited by 1966chevy; 06-01-2015 at 08:54 PM. |
02-18-2015, 01:56 PM | #9 |
PM sent
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-13-2015, 07:04 PM | #10 |
1954-1987 Chevy GMC Truck Stepside Tailgate Hinge Trunnion "Patent pending"
Ultimate Hinge Trunnion (4 Piece Set) made of Stainless Steel/Delrin replacement part! Made in USA! These are very quiet while opening and closing the tailgate. See the pictures Website is: tdtrunniondesign.com Available on Ebay right NOW! http://www.ebay.com/itm/171718930810...84.m1555.l2649 These are hinge trunnion replacement parts to upgrade your Chevy Stepside Truck. The Trunnions are manufactured from Delrin and 303 stainless steel. I have a picture listed of the replacement trunnions that are zinc plated which will still rust on your truck. I also show the original trunnion that was removed and has rusted and made that awful sound while opening and closing the tailgate. You can reuse your bolts and lock washers, but would recommend you use stainless steel bolt and lock washer. Be sure to use an antilock lube when reinstalling your Trunnions, prevent bolt lock! Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck just in reverse of how you removed it from the truck. No more greasing the trunnion, No more rusting, No more noise with a huge improvement, smooth opening and closing of your tailgate! You'll love it! Free shipping USPS in 50 states. Material used: Delrin is a Acetal AF blend, supplied as a 2:1 blend of Acetal AF-100 and Acetal 150 resins, has excellent sliding/friction properties. Bearings made of Acetal AF blend can operate at higher speeds while exhibiting reduced wear. These bearings are also essentially free of slip-stick behavior because the static and dynamic coefficient of friction are closer than with most plastics. Acetal AF blend retains 90% of the strength that is inherent in unmodified Acetal. 303 Stainless Steel is very similar in properties to that of 304 Stainless Steel, However 303 has an addition of sulfur for better machining characteristics. 303 Stainless Steel is Corrosion resistant to temperatures of 1500 Degrees or more. It is used in screw machines, food processing equipment, marine applications, and some aerospace application. |
03-13-2015, 07:20 PM | #11 |
How easy are these to replace?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-13-2015, 10:29 PM | #12 |
03-15-2015, 09:34 PM | #13 |
guess i'll have to read up on how to take the tail gate off... never done it
04-03-2015, 10:08 PM | #14 |
Has anyone installed these and can give a report?
06-01-2015, 08:55 PM | #15 |
My reviews on the Tailgate trunnions have been very good! See my eBay account and feedbacks.
I installed them on my vehicle and they work great!! Summer price break!! Price reduced 66-72 Fleetside Tailgate Trunnion on the eBay. http://www.ebay.com/itm/171709176937...#ht_559wt_1094 I also in the works on building 67-72 trunnion hinges. http://www.ebay.com/itm/171709178881...#ht_430wt_1094 Website is: http://tdtrunniondesign.com 47-87 Stepside Tailgate Trunnions on the eBay. Available on Ebay right NOW! http://www.ebay.com/itm/171718930810...84.m1555.l2649 My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896 66 chevy truck Fleetside LS1 67 Camaro Convertible 327 |
06-02-2015, 01:10 AM | #16 |
Proud owner of a 55.1 AD
Interested in a set for my '72 Jimmy. Is the eBay $72 shipped price the summer price reduction?
Any other feedback on these? Thank you, Bob |
06-02-2015, 07:21 AM | #17 |
Thanks for the info!!!!
06-02-2015, 09:41 AM | #18 |
Yes, This is the cheapest I can go with fees I have to pay, $5.50 for shipping and $7.20 to eBay. I do offer local pick up, $65.00. They are normally $75.00. Thx
10-01-2015, 12:51 PM | #19 |
I have been getting rave reviews on these items. Check out the Product reviews below!
Summer price break Continues!! Available on Ebay right NOW! Price reduced 58-66 Fleetside Tailgate Trunnion on the eBay. http://www.ebay.com/itm/171709176937...#ht_559wt_1094 67-72 Fleetside Tailgate Trunnion on the eBay. http://www.ebay.com/itm/171709178881...#ht_430wt_1094 47-87 Stepside Tailgate Trunnions on the eBay. http://www.ebay.com/itm/171718930810...84.m1555.l2649 Website is: http://tdtrunniondesign.com My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896 66 chevy truck Fleetside LS1 67 Camaro Convertible 327 Ebay Product reviews Fast shipping and worked perfect. 67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET thanks for the trunnion hinges, fast shipping, great price, will buy from again! 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET great part, really helped with the rattling tailgate problem 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET I have been hyping you up in instagram & the 47-72 truck forum. Great product! 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET Quick and easy...product is awesome, Thanks 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET Item as described, fast shipping...Thanks! 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET Great seller! Super fast shipping! Amazing quality product! Thank you! 67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET Quality Product MADE IN THE USA well packed FAST SHIPPING thanks again 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET Quick and easy service with high quality parts. 1954-1987 Chevrolet GMC Truck Stepside Tailgate Trunnion Hinge SET awesome 58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET Nice Looking product, fast shipping. Would buy again! 67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET Nice product 67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET Last edited by 1966chevy; 10-01-2015 at 12:58 PM. |
