Old 03-28-2017, 05:05 PM   #1
Ryan Duke
LS swap radiator, other than entropy and R&D
SO after alot of forum searching, it seems like people argue over entropy and r&d. Does any one have experience ordering an ls radiator from summit,jegs, speedway and mocking it up them selves? Other than a plastic radiator from the boneyard? I feel like we could save a few bucks doing it this way. I found a few radiators that seem like they fit, but I never had a stock radiator to get measurements from.
Ryan Duke is offline   Reply With Quote
Old 03-28-2017, 06:36 PM   #2
72MARIO
72MARIO's Avatar
Re: LS swap radiator, other than entropy and R&D
I got my rad from Sparkey R&D the quality looks to be good and I have had no problems with cooling "the engine"
. I didn't do my home work and missed that on his ls swap rads the outlets are moved to the passengers side. That made for a nightmare finding hoses that fit. He was no help making suggestions on what could work. In the end 1996 jeep grand Cherokee 4.0 hoses fit great.
He did tell me the transmission cooler was moved to the drivers side. That's fine. That makes running the transmission lines a little more difficult. I got over it and the problems mounting the fan shroud.
I was very specific when I ordered it that I wanted to use the factory fan shroud and did not want to modify mounts to make it fit. Well it turns out if you have 3 core mounts the fan shroud will not fit. You need 4 Core mounts
Here is a picture of my transmission temperature without a external cooler also look at the intake air temperature to have a Idea how hot it was out side. I ended up bypassing the rad trans cooler and went with a B&M super cooler and fan kit. I have a ton of money into my 4l80E and cant risk 220+ temperatures empty cursing the hwy.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-29-2017, 10:24 PM   #3
Dustytrix
I used a stock radiator from 02 camaro, it fits good. I had to drill new holes to use top mounts. But the hose locations, trans fittings, and air bleed hole for heads is where you need them.
Dustytrix is offline   Reply With Quote
Old 03-30-2017, 12:29 AM   #4
t300
I'm using an aluminum unit from "speed daddy" on eBay. Comes with trans cooler hookups, bolted up to rad support using stock mounts. Even came with 2 electric fans although I'm still using the lq4 clutch fan. Seems to work fine. For $160 and free shipping it was worth a try and so far so good
t300 is offline   Reply With Quote
Old 03-30-2017, 09:27 AM   #5
Willie Makeit
Willie Makeit's Avatar
stock 4 core.
cools fine with an AC condenser and a water-to-air intercooler heat exchanger in front of it.
Willie Makeit is offline   Reply With Quote
Old 03-30-2017, 09:58 AM   #6
LS short box
I used a Summit dual pass radiator with a 16" Spal fan on a couple of applications and they cool very nicely. External trans cooler.
The dual pass has the inlet and outlet on the passenger side for easy hose hook up.
Old 04-02-2017, 01:12 PM   #7
PEDROSKI
PEDROSKI's Avatar
I used a Spectra cu730 (454 radiator) in my 76. Bought the 454 bushings and a factory 454 top plate. No issues and great fitment.
72 2wd k5 blazer
86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE
Old 04-02-2017, 06:05 PM   #8
jessemthompson
I'm using a Holley frostbite in my 72. It's working great so far.
jessemthompson is offline   Reply With Quote
Old 04-02-2017, 09:59 PM   #9
boynton
boynton's Avatar
Used a Speedway generic radiator on mine and ran external coolers for the trans and oil.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 04-03-2017, 09:58 AM   #10
72blu
72blu's Avatar
I used an engineered cooling products rad that was built for our trucks and the fitment was perfect. It also came with duel electric fans. So far so good haven't really driven the truck in hot weather yet so I can't really give a total review but for now its been great, no issues.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges
1972 SWB Custom 10, gauges, cammed LQ9, M22
72blu is offline   Reply With Quote
Old 04-03-2017, 11:36 AM   #11
suburban99
suburban99's Avatar
In my '62 5.3/4L60E I used a champion off eBay...make sure the spouts are welded and not pressed on..worked fine for me..
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-03-2017, 08:25 PM   #12
Street Smart
Street Smart's Avatar
You can go ROCKAUTO.COM to get specs on any radiator you want. I used a stock radiator for a 96 C1500 v6 pick up perfect fit, proper hose sizes for the LS.
http://www.rockauto.com/en/moreinfo....031487&jsn=577
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 04-03-2017, 09:19 PM   #13
Clyde65
Clyde65's Avatar
Champion and American Eagle!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-15-2017, 11:29 PM   #14
AustinBelair
I need to order one ASAP. Any other suggestions? I'd love to run a crossflow but I don't think they will fit using the stock battery box location? This is a 400HP LS1 with Vintage Air and a 4l80E
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 04-15-2017, 11:55 PM   #15
boynton
boynton's Avatar
eBay http://www.ebay.com/itm/351599620760
This is the one I bought and it fits well. I haven't run it yet but I don't forsee any issue with it.
1970 SWB Step-Side
Old 04-18-2017, 07:25 AM   #16
Ryan Duke
Because I'm running a 2010 vette motor I elected to get a 2010 vette radiator and fans but the radiator doesn't have a fill port on it so I looked at dimensions of the 2011 and 2012 vette and camaro radiators. The stock 2011 camaro radiator uses the same hoses as the vette so I bought all new hoses, cap, radiator, and fan assembly for a 2011 camaro and it will all work. I will have to cut up my core support but that doesn't bother me. But it saved me a lot. Entropy was around 850 shipped and rnd wasn't far off. I paid 440 shipped for all new stuff from rock auto, the other cool thing as previously stated was you can see what sizes they are before you buy them
Old 04-18-2017, 10:13 AM   #17
scoot_mcgrute
I picked up a Northern radiator last year when I had the inline 6. It was cheap, not a direct fit for my 66 but it fit well, and is compatible with the LS swap I'm working on right now. Neat thing about their radiators is that they sell an electric fan setup for each one they make. My buddy has run Northern radiators in 3 of his last 4 projects with no issues.
It's P/N 209676 for anyone that is interested.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 04-18-2017, 09:43 PM   #18
Sturvin
New engines should fill from the cap on top of the water pump right?
Sturvin is offline   Reply With Quote
Old 04-18-2017, 10:04 PM   #19
mongocanfly
mongocanfly's Avatar
Cap on top of water pump?..I've never seen that..got a 2011 ls3, a 2013 5.3 and neither have a cap on water pump...
Old 04-18-2017, 10:13 PM   #20
Sturvin
I guess most of the more recent engines I have seen have been on cars, water pump may be set up differently. The radiator is sealed with a filler neck going to the top of the water pump. That's where the breather line to the surge tank is too.
If you have air stuck in your rad you have to burp it out by squeezing your upper rad hose.
Old 04-19-2017, 07:58 AM   #21
boynton
boynton's Avatar
Ls car motors fill from the overflow tank.
1970 SWB Step-Side
Old 04-19-2017, 11:16 AM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
....Where exactly does this cap exist?
System gets filled from the res tank if your running one, otherwise right into the radiator on plenty of swap trucks.
I saw Ryans truck in person, and the amount of trimming to fit his new rad is actually really small. Its just about the 3/8" lip on the backside of the core support, so it sits flush and has something to mount to.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2017, 05:50 PM   #23
crakarjax
crakarjax's Avatar
Is this the rad, and were the hose sizes matched to the LS water pump?
http://www.rockauto.com/en/moreinfo....379976&jsn=454
Thinking about this aluminum version... http://www.ebay.com/itm/3ROW-CORE-AL...BY3xa4&vxp=mtr
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-24-2017, 07:01 PM   #24
mongocanfly
Been reading good things on champion...
Old 04-24-2017, 09:49 PM   #25
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Originally Posted by Willie Makeit View Post
stock 4 core.
Exactly what I used. Had Rad shop change upper hose diameter and add steam port. Works perfect. No need to get exotic
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
