11-12-2019, 09:24 AM | #1 |
Need a SPDT brake switch
I'm looking for a brake switch to fit to a squarebody pedal. It needs to send 12v to the body control module when not applied, and send 12v to the engine control module and brake light circuit when the brakes are applied.
A single-pole double-throw switch with a threaded body would be perfect for my application. A google search didn't yield much. Does anyone know of a simple factory-type switch that would accomplish what I want?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
11-12-2019, 09:31 AM | #2 |
Re: Need a SPDT brake switch
I believe you want a brake light switch for cruise control.
https://www.rockauto.com/en/catalog/...t+switch,10474
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
11-12-2019, 10:25 AM | #3 |
Who Changed This?
The switch for a vehicle with a lock-up converter would also work. It opens on the converter-enable side when you apply the brakes.
11-12-2019, 02:46 PM | #4 |
rpmerf and steeveedee, thanks a lot! It never occurred to me that my truck may have been optioned with a switch like that from the factory. That definitely simplifies the task.
Now, to find some way to mount a 2010 Camaro clutch pedal sensor to my clutch pedal...
11-13-2019, 01:20 PM | #5 |
Cruise control needs to release when you press in the clutch. I see a cruise control release switch on rock auto. I would think this would be mounted on the clutch pedal.
There is also a clutch safety switch, but it looks different, so I am not sure how it mounts.
11-13-2019, 01:41 PM | #6 |
I'm using a hybrid between a 2010 Tahoe and a 2010 Camaro computer system. The Camaro is expecting a three-wire hall-effect sensor for the clutch. This will be used for cruise cancel within the ECM, and I think there's several coast-down tables specifically related to a depressed clutch pedal. Since I'm not intending to crank the engine through the BCM and ECM, The ECM will not prevent me from cranking without pressing the clutch. For that, I'll have to retain a stock '87 clutch switch.
11-13-2019, 03:14 PM | #7 |
blood type; Retumbo
the clutch switch you're talking about isn't a hall effect, it's actually a voltage divider and it's very similar to the brake pedal position sensor
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-22-2019, 08:47 PM | #8 | |
What's the chance I can swap these out for SPDT switches? If all I'm worried about is off-vs-on for cruise cancel and deceleration-fuel-cutoff, this should be sufficient. Right or no? I've got a Camaro switch in hand. I just don't have small enough alligator clips to get a good hold on the thing. I have an idea for testing it, but it's pretty ghetto. I was just hoping maybe you've been down the same road, and can advise on swapping for a simpler switch.
