Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-19-2020, 04:23 PM   #1
67C10Step
67C10Step's Avatar
How much to cut when doing rust repair?
I am FAR from doing any major body work or panel replacement on my truck but I'm starting to think down that road.
On my floor boards the inner and outer rockers are obviously going to need to be replaced but I am torn on what to do in the floor. It is bad in the kick panel area to about six inches in and about ten inches back. I know you can purchase the floor panel that goes all the way to the hump but I am thinking I would cut out only what is necessary to get back to solid metal and keep as much of the original steel as possible.
Thoughts and experiences? How many of you have abandoned your interior fresh air vents due to rust? Mine don't look so hot, particularly around the bottom, curved area around the damper hole.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 03-19-2020, 04:29 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: How much to cut when doing rust repair?
I'm not familiar with your truck ,but is the floor pan spot welded in?... , if so youd be better off just replacing it as a whole instead of trying to piece it together.. ...will depend alot on what you have to work with though
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-19-2020, 04:32 PM   #3
67C10Step
67C10Step's Avatar
Mongo,
Mine is a 67 c10 so the floor is solid to the center hump. If it was a spot welded panel I'd probably agree. Overall, it's not as bad as some I have seen but not nearly as good as I wish it were.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 03-19-2020, 07:07 PM   #4
my67c20
It all comes down to picking a spot where there is good metal, but not so much that you have miles of seams to weld. Lots of repop panels do not match OEM, so there is always some massaging that needs doing. I replaced rockers both sides, plus some of the floor pan and toe kick area, but not so much that I started to have to deal with bracing.
my67c20 is offline   Reply With Quote
