07-05-2022, 07:30 PM | #1 |
Frame question
This is gonna be a different question from the normal....has anyone lengthened a frame ? The reason I ask is because I have a 68 GMC 1 ton longbed stepside and I want to get rid of all the 1 ton suspension so I can get a better ride. The 1 ton has a 9 foot bed and I want to keep it that way. So I was thinking about trying to get half ton frame and lengthening it. Any thoughts ?????
1968 GMC stepside long bed 2004 GMC Yukon 2004 Chevy SSR 1969 Chevelle SS 1946 Chevy 4 door sedan 1923 C-Cab |
07-05-2022, 09:02 PM | #2 |
Re: Frame question
Can you not put lighter suspension parts ( 1/2 ton or 3/4 ton front crossmemeber & springs and smaller leaves on the back )on to get a better ride?
I got a bench seat baby, you don't have to sit over there. |
07-06-2022, 12:23 PM | #3 |
Re: Frame question
I am not sure but I don't think the lighter duty parts will fit. I think the 1 ton frame is taller.
07-06-2022, 12:36 PM | #4 |
Re: Frame question
The 1 ton frames are entirely different in the rear. Leaf spring spacing is different along with the width of the frame, and you are correct the frame beams are taller. What wheel base is the 1 ton?
07-06-2022, 01:12 PM | #5 |
Re: Frame question
It has a 133" wheelbase
07-06-2022, 02:14 PM | #6 |
Re: Frame question
Lot of work to lengthen a frame only 6''. You'll then have to drill different mounting holes in the bed to the frame as they will be in a different place (width wise)
07-06-2022, 02:17 PM | #7 |
Re: Frame question
You can accomplish this, being as it would be easier than stretching a different frame and swapping everything over. OR just find a different truck altogether and sell this one to somebody that needs an older 1 ton
07-06-2022, 02:51 PM | #8 |
Re: Frame question
On the front end, you can swap on 1/2 ton upper and lower control arms.
Maybe look into seeing if you can make 1/2 ton leaf springs from a GMC work with the 1 ton hangers? Might need to make some spacers if the spring eyes are smaller than the hangers. Just trying to think outside the box of a full frame swap
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-06-2022, 07:44 PM | #9 | |
Re: Frame question
These 1 ton pickups supposedly aren't rare, but I don't exactly see them growing on trees; save this truck for someone who needs it or save it for another time for yourself. ......then again who's to say the next person to own the truck won't just lay down the cash and promptly say, "yep I'm gonna cut 'er up and make 'er one of them shortened slammed restomods...." |
07-06-2022, 07:50 PM | #10 |
Re: Frame question
Would a longhorn frame work?
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
07-06-2022, 08:11 PM | #11 |
Re: Frame question
07-06-2022, 10:15 PM | #12 |
Re: Frame question
07-06-2022, 10:18 PM | #13 | |
Re: Frame question
07-06-2022, 11:09 PM | #14 |
Re: Frame question
We're starting to rant off topic here, but most of that statement was half hearted sarcasm. In reality there are still plenty of these trucks left for everyone, plenty left to be plundered if so desired.
07-07-2022, 01:24 AM | #15 |
Re: Frame question
No, you started the rant. I was giving him an option then you stepped in with nothing. Take it somewhere else.
Adding to a frame is A LOT of work if done the right way. I've done it several times. |
07-07-2022, 06:24 AM | #16 |
Re: Frame question
Ok, we're all good now, right?
What I see here is only the need to switch out springs. I think the rear leaf springs are the bulk of the issue. You can try removing some or build a new pack to lighter specs On another note. what make truck is your '23 C-cab?
07-07-2022, 12:03 PM | #17 |
Re: Frame question
He would have to lighten the 1 ton springs as they are 2-1/2'' wide as opposed to the 1/2 and 3/4t springs are 2-1/4''. Front springs may remain if the truck is toting a big block. He would have to get a little creative with the rear pack removing leafs while keeping height where he wants it, but it could be done
07-07-2022, 01:34 PM | #18 |
Re: Frame question
The c-cab is a ford
