03-01-2021, 05:58 PM | #1 |
gear box ripping out
Hi all,
I have a 90 burb with a sagina gear box. The bolts have ripped through the frame. any way to fix this? is there a reinforcement plate or something I can purchase?
1990 suburban r1500 k 350 2wd |
03-01-2021, 06:48 PM | #2 |
Re: gear box ripping out
That sounds pretty crazy. Any pics?
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
03-01-2021, 07:14 PM | #3 |
[image]https://photos.app.goo.gl/jY2ixQqcFLT4fTHv7[/image]
[image]https://photos.app.goo.gl/JnFnea7azXd92zgaA[/image] [image]https://photos.app.goo.gl/Lz7gwUFwxa6pTUw97[/image] [image]https://photos.app.goo.gl/XRtt1TbH1U7wbG8Z8[/image]
1990 suburban r1500 k 350 2wd Last edited by Palf70Step; 03-02-2021 at 12:26 PM. Reason: Adding pictures |
03-01-2021, 07:23 PM | #4 |
03-01-2021, 07:55 PM | #5 |
they sell plates to weld on and reinforce that area.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
03-01-2021, 08:00 PM | #6 |
cant see your pics ,but its pretty common..especially 4x4s with bigger tires..
4wds use these plates https://www.ebay.com/itm/38197903534...SABEgKc6PD_BwE and there are these https://www.offroaddesign.com/weld-o...gm-trucks.html
03-01-2021, 08:14 PM | #7 |
It's a 2wd.
what's the kit called? what should it cost to have someone repair it?
03-01-2021, 10:31 PM | #8 |
Here is your pictures.
03-01-2021, 10:35 PM | #9 |
Thank you sir.
what did I do wrong?
03-01-2021, 10:43 PM | #10 |
I an not sure. something with the {image} frames.
Here is the bracket you need. It can be easily fabricated. .
03-02-2021, 12:17 AM | #11 |
I would approach this as a two-step fix. First is to weld up your frame using one of the repair plates that mongocanfly mentioned. The second step, is to install a brace kit like getter-done mentioned. This brace kit helps stabilize the box by bracing it back to a crossmember, and makes it less likely to break the frame again.
If you're wanting to hire the whole job out, find a local mechanic who's comfortable with welding and fabrication work. Buy the repair plate and the steering box brace, and have the mechanic install them. I would expect the repair to take anywhere from three to six hours. He'd have to remove the driver's side wheel, unbolt the steering box, clean up the frame, weld in the new plate, bolt in the brace, and reinstall the steering box.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
03-02-2021, 01:50 AM | #12 |
The plate linked is a 'reinforcing plate'. That means you have to repair the frame first, then install the plate. Repairing the frame means removing the box and getting all the pieces you can back into place and welding them, then smoothing it all out front and back. Then you put the plate in and start all over again molding the plate to the frame with a rosebud torch end. I've done probably a couple dozen of these repairs in both 2wd and 4wd. I've even had to replace that section of frame back to the center body mount a couple of times. It is pretty labor intensive.
03-02-2021, 08:49 AM | #13 |
Thank you all.
Very helpful.
03-02-2021, 10:30 AM | #14 |
Use Offroad designs plates and brace. If there are any cracks make sure to stop drill, and 'v' the crack and weld it up i have used two of their setups and they are quality products.
84 step side 87 swb |
03-02-2021, 11:18 AM | #15 |
That level of damage i would buy both the weld on repair kit and bolt in brace kit .
Fix the frame first . Stop drill all the cracks . Then bolt the repair plate on nice and tight via the 4 holes the box bolts on with . Stitch weld it like the directions show . Then bolt on the box and brace kit . With the weld on repair kit and bolt on brace kit you might need longer bolts for the whole sandwich . And make sure you get a bolt in brace for 2wd . As there didferent over 4wd .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
