08-18-2023, 03:46 PM | #1 |
Sorry...another HEI plug wire thread
I have a stock 400 BB, no ram horn manifold.
I'd read here, plug wires for a 75 vette will fit. Bought a set at Advance. The clips for both ends did not click on as they should. They were real loose. No one there could help further. Another search here, I bought a set of AC/Delco 9088S wires. The plug end is a 90 vs. a straight boot. They are way too close to the exhaust manifold. So close, I can not get the #4 wire on the plug. They are going back to Amazon. Another 2 hours of searching... ... maybe AC/Delco 9508D will fit. ... maybe Napa bel700103 will fit. This one has a coil wire which I still have. I know some will say...buy bulk, make your own. I tried that years ago. In my case, was a waste of $'s. Never could get the connections correct. Thanks much...Don. |
08-18-2023, 04:19 PM | #2 |
Re: Sorry...another HEI plug wire thread
The 75 vet wires are for a small block with HEI. The end will not fit on a points distributer which you have found out. Some of the wires are so short they probably will not fit a BB. After many frustrating experiences I switched to making my own. I buy bulk MSD wire, boots, and ends, and most importantly a quality set of real spark plug wire crimpers. After 2 or 3 trials they can be made up in about 3 minutes to whatever length is right for you. Good luck, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-18-2023, 05:00 PM | #3 |
I made my own too and it was very satisfying to get the right lengths just how I wanted them..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-18-2023, 07:17 PM | #4 |
What type exhaust manifolds and what type distributor?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 08-18-2023 at 10:12 PM. |
08-19-2023, 07:44 AM | #5 |
08-19-2023, 09:08 AM | #6 |
Does the distributor cap have male or female terminals?
Do your exhaust manifolds look like these?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
08-19-2023, 02:20 PM | #7 |
08-19-2023, 10:20 PM | #8 |
1975 Chevy truck with 454 will work, OEM style have straight boots. I got mine from NAPA, don’t remember the part number. Only put 500 miles on them before I put headers on the truck and went with 135 degree boots. I might still have them. If you are interested let me know and I will look for them.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-20-2023, 12:08 AM | #9 | |
This is what I used on my 68 396 when I went to an HEI distributor. Stock manifolds and it worked well. They have an HEI end for the distributor and straight caps for the plug end. I also tried the Corvette wires first and realized that was a small block solution.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
08-20-2023, 04:22 AM | #10 |
OK, I'm a dumbass. You said 400 BB, and for whatever reason I was thinking 400 small block. Listen to the two comments above.
08-20-2023, 10:50 AM | #11 | |
I used a set from a 1976 454 for a chevy C20. But maybe they aren't the correct lengths for folks who want a very clean and organized look. The brand is a popular very high quality Japanese brand--popular with Japanese car folks for many many years--NGK. NGK 51373 ~$30 They're bright blue which might bother some folks, I don't care about color, i just want something I KNOW is high quality. It doesn't hurt that they glue the boots to the wires. Last edited by jumpsoffrock; 08-20-2023 at 10:57 AM. |
08-20-2023, 12:19 PM | #12 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-20-2023, 02:25 PM | #13 | |
But my point isn't about how absurd GM is, but rather about helping folks specify what exactly they're working on so the get the most accurate info. I don't think I've ever seen quite as much confusion as I've seen on GM forums with people mixing up 400 sbc's and 402 BBC as a result of GM's odd badging and literature. |
08-20-2023, 03:43 PM | #14 |
08-20-2023, 06:12 PM | #15 |
I didn't mean to start a battle here! If I had looked past the "400", I would have seen the BB and would have known it was a 396 or a 402, regardless of what Chevrolet called them.
08-20-2023, 07:31 PM | #16 | |
08-22-2023, 04:28 PM | #17 |
Deed is done.
I bought Napa part # bel700242. Straight boot on the plug, 90 on the dizzy. #5 was a bit short but I made it work. All others were goo to go. Thanks all...Don. |
08-22-2023, 04:31 PM | #18 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
