02-11-2013, 02:23 PM | #1 |
Tires???????
So I got 275-60-15 on my truck want to put basically a all terrain tire on it since it is a work truck what size to put on it note it is 2WD no lift on it
02-11-2013, 04:28 PM | #2 |
Re: Tires???????
31x10.50 should fit fine, I had 32x11.50s on my 82 2wd with no lift and would barely make contact wit the inner fender and the upper fender lip. I rolled the lip a bit so it wouldn't cut the tires. That was in the front, in the back the 32x11.50s fit just fine.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-11-2013, 08:50 PM | #3 |
Re: Tires???????
bfg rugged terrain 265/70/15, they are close to 30x10.50
http://www.tirerack.com/tires/tires....=yes&tab=Specs
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
02-12-2013, 05:03 AM | #4 |
Parts and more parts
Re: Tires???????
The 275/60/15 tire is basically a 27.99" tall tire and the 275/70/15 is a 30.16" tire. That will change your rear end gearing a lot, even if it fits under the fender. If you are running a rear end ratio that is 3.42 or lower, then you will experience some issues with acceleration and also with RPMs at highway speeds and fuel consumption.
http://www.discounttiredirect.com/di...foTireMath.jsp
Frank |
02-12-2013, 11:29 AM | #5 |
Re: Tires???????
why not run a 235/75R15...lots of choices for tires, and probably what your pickup had stock.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
02-12-2013, 11:58 AM | #6 |
Re: Tires???????
Done deal haha. I was going to go with some A/T tires but decided against it. I've had cooper cobra's on most of my vehicles and I'm glad I got them for this truck too. Mine is only 2wd as well, but I haven't had any problems getting stuck off road. Granted I mostly go off into some mud here and there, (and more recently snow), nothing crazy but I've been fine so far. Unless you are planning some serious wheeling You can get away with standard type tires without a problem. This is all just info to use as you see fit. Personally, if I had a bit more cash at the time I would probably have gone with General Grabber AT2's in 265/70/15. Good price, great reviews, and quite the sexy tread pattern if I do say so myself. http://www.tirerack.com/tires/tires....omCompare1=yes
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
02-12-2013, 12:07 PM | #7 |
Re: Tires???????
i run cooper brand tires on all of my vehicles....but a cobra on larger/heavier vehicle will wear pretty fast. i run cooper discoverer h/t tires on my 2wd blazer....6 ply.
02-12-2013, 12:29 PM | #8 |
Re: Tires???????
I've never tried them on anything this heavy, hadn't heard anything before about them being bad for a truck.
02-12-2013, 12:31 PM | #9 |
Re: Tires???????
i don't think it's a question about bad...just expected tire life.
