12-26-2020, 01:54 PM | #1 |
low n' slo
radiator selection
what are you guys doing for radiators with an ls swap? i bought this one i planned to run woth my old 305, but not sure it will work with the new motor. hell, i dont even know if it wouldve worked with the 305, never seen the road long enough lol.
id like to continue to use this, ut if not i will have to be on the search for a replacement.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-26-2020, 05:02 PM | #2 |
Re: radiator selection
i bought an all alumin one from cold case with fans
12-26-2020, 05:53 PM | #3 |
I like dual pass radiators on LS swaps. The inlet and outlet are on the passenger side of the radiator. Makes coolant hose routing much cleaner. My 68 has Afco dual pass universal fit. I modded the upper and lower stock mounts to work with the Afco radiator.
See attached pic. |
12-26-2020, 06:32 PM | #4 |
kev2809, what truck are you working with?
The squarebody radiators are frequently used in LS swapped squarebody trucks. The inlet and outlet ports are in the correct location and are the correct diameter for stock LS hoses. Depending on what mounts you use, the LS mechanical cooling fan might or might not align correctly with the fan shroud.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
12-26-2020, 07:23 PM | #5 |
low n' slo
probably shouldve put truck info in the first post...
67 suburban. i bought this radiator from a friend a while back. he usually only buys or builds 90s model silverados. im assuming that was the intention for this radiator. im hoping it will work to keep my costs down. is there any other measurements needed?
12-26-2020, 09:37 PM | #6 |
If you can physically mount it to the core support, and if you're willing to run electric fans, it will be fine.
If you want to run a mechanical fan, you'd better stick with a radiator and fan shroud setup from 1967. Pair that with a set of LS 67-72 mounts that put the LS engine in the same place as a SBC, and the fan "should" line up.
12-27-2020, 02:35 PM | #7 | |
low n' slo
12-27-2020, 04:38 PM | #8 |
I'm running the stock radiator that was in front of my 350...never had a issue with overheating..normally runs around 175-180 ....it does have dual electric fans though..
12-27-2020, 05:53 PM | #9 |
I always use mechanical fans whenever possible, but a lot of people just have to have electric fans for some reason. Once you have an electric fan burn up 1000 miles from home, you change your opinion of them though. LOL!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-27-2020, 07:05 PM | #10 | |
I'm installing electric fans. My reasoning, is 95% of my driving is short 1-mile trips, or highway-speed cruising. I won't need fans in either scenario. With electric fans, they'll mostly just sit there unused. I'm very rarely driving in stop-n-go traffic, and I'm not installing air conditioning. My engine mounts will allow for a mechanical fan though, so if I have problems, I could easily swap it out.
12-27-2020, 11:51 PM | #11 |
Kind of disagree on the electric fan statement. You would be hard pressed to find a mechanical fan on a current daily driver. Anything with AC will have either two fans or a single two speed fan.
The key to making a electric fan live a long life is good wiring and quality relays. Also a quality fan maker. I always buy Spal fans. Never had a failure. Just got done plowing the driveway with my 98 Wrangler with a LS6 swap. Did the swap 12 years ago? and the fan is still working like a champ. If you think you might have a failure buy an extra fan assembly and keep it in the car/truck. I do that with the 255 fuel pump and never had to use it. Just my.02. |
12-28-2020, 05:04 AM | #12 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 12-28-2020 at 05:18 AM. |
12-28-2020, 10:27 AM | #13 | |
Ultimately, I have no issue using either. Parts fail. I've had 200+k mile electric fans (the ones in my squarebody, for instance) that have lived a harsh life of all dusty/unpaved roads, and I have had 200+k mile clutch fans. I've also had both systems fail at about the same rate. Both do the job intended. For the original poster, I'm using a 2006 GMC Yukon 34" core radiator with the surge tank and the dual fan setup out of that same Yukon. I've only got one wired in right now and it keeps the truck plenty cool enough. The radiator you posted looks like it will physically work. |
12-28-2020, 11:09 AM | #14 |
My 2 cents is whether it is an electric fan, fuel pump or whatever if it’s a vehicle that you Drive on a regular basis and put miles on use parts that can be readily available at a local parts store. I have electric fans because of engine position as well as the engine coming from a car was not set up for mechanical
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
12-28-2020, 03:28 PM | #15 | |
12-28-2020, 12:53 AM | #16 |
My reason for using electric fans is due to the mech fan not lining up with the radiator or the shroud...the top of the mech fan was close to the center of the radiator..
12-28-2020, 09:29 AM | #17 |
Which truck was this? I figured at least your squarebody truck would have been pretty close to correct.
12-28-2020, 06:55 PM | #18 |
low n' slo
this truck will not be daily driven at all, just a weekend cruiser. well, i do have the whole donor truck so i could use the 01 yukon radiator if i need too, but i believe the current one i have will give me a lot more space if i run a mech fan....plus i could sell that stock one off the donor. i will have my current one taken to my.local rad shop and have em flush it and pressure test it to make sure its good to go.
one question though, i read a lot about these swaps and people mention they have a steam line welded in for the ls. what the hell is that?
12-28-2020, 07:52 PM | #19 |
The steam line in the radiator hooks to the steam lines that are bolted to the front of the heads. Some people tap the water pump and hook it to that, some people cap them off and say they don't have a problem, but GM put them there for a reason, to get all the air out of the system to keep from creating hot spots in the head is what I'm told.
12-28-2020, 08:43 PM | #20 |
Lookong for a radiator for my LS swapped 64 atm. Been eyeing this one, all I need is a fan relay setup and would be in business. I like that it has built in trans cooler as well.
https://www.universalpartsinc.com/sh...?i=1117308&c=0
1964 C10 Resto-mod 5.3L - L59 |
12-28-2020, 09:01 PM | #21 | ||
low n' slo
12-28-2020, 09:36 PM | #22 | |
https://jagsthatrun.com/products/fix...v8-engine-swap I wouldn't expect to get much resale value out of a used radiator. They're cheap enough new, that most folks don't even bother to check marketplace before just buying a new one. At least mock up the 2001 radiator, shroud, surge tank, and mechanical fan, and see if they could be made to fit. That would definitely be the way to go if you can get the components to fit in nicely. The challenge will be getting the engine to sit in the same relative position to the radiator as it was in the original donor vehicle. This is so the fan and the shroud align correctly.
12-28-2020, 11:36 PM | #23 |
Kipps... the IH was way off...not even close to center...the C30 wasnt as bad but it didnt line up in the factory shroud..
12-29-2020, 09:22 AM | #24 |
I pulled and reinstalled two transmissions on these classic trucks. Both were manual. A 1987 chevy 4wd, and a 1981 Ford 2wd. The chevy was missing the extra brace pieces that went to the top flange on the frame rail. I didn't worry about it. The Ford had those braces, but I don't remember if I bothered to reinstall them or not.
Just drill new holes in the bottom frame flange, and call it good. It's not worth the trouble attaching it to the top flange, in my opinion. As far as rivets vs bolts, it'd be REALLY unhandy to do a clutch job without removing the crossmember. Probably impossible on some transmissions. If there's rivets there, cut them off, and replace with bolts.
12-29-2020, 10:00 AM | #25 |
I should have been more specific, the crossmembers are riveted in on manual transmission equipped Chevy and GMC trucks from 67-72. I suspect they stopped doing that in 1973 when the body style changed.
