Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-22-2021, 09:48 AM   #1
blazer2007
putty for chrome trim clips?
I remember along time ago when I put on my side trim for my 78 the guy gave me some putty type stuff that looked like string licorice but gray. You wrapped some around the trim clips and it would seal so no rain would get in the holes on the body. These are the big clips that you drill holes in the body. I don,t what it is called or where to get it now or if there is an alternative . I don,t need much.
blazer2007 is offline   Reply With Quote
Old 04-22-2021, 12:11 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: putty for chrome trim clips?
3M strip caulk
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-22-2021, 04:25 PM   #3
blazer2007
would that be body shop or hardware store and thanks
Old 04-22-2021, 06:35 PM   #4
mongocanfly
Post Whore
Some parts stores carry it,,,so do auto paint supply stores....I got mine off ebay
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-22-2021, 09:20 PM   #5
lupo
Having worked on a lot of old cars with a lot of stainless steel trim the problem is the clip scratches the paint around the hole it starts to rust and the rust travels . When you pull stainless steel trim off of 50s car there is usually quite a bit of rust. Apply Aluminum pigmented permanent rust sealer around these holes and in that area because once you scratch it the rust will not travel beyond the scratch and will seal whatever existing rust was under the trim. 2 coats. Then prime and paint. Then you can use your 3M caulking strips. It was the first thing I addressed when I wrote the Tip Sheet. Hope this helps
lupo is offline   Reply With Quote
Old 04-22-2021, 09:20 PM   #6
blazer2007
Thanks,I went to the body shop supply guy and he hasn,t sold any in 5 yr,s. I would have to buy a large amount , it comes in 2 lbs. box. I will try hardware store . At least I know what it is called.
Old 04-22-2021, 10:37 PM   #7
mongocanfly
Post Whore
The box is the smallest quantity I've seen
Mongo...aka Greg
RIP Dad
RIP Jesse
