06-14-2019, 05:43 PM | #1 |
Spark Plug reading
Hello,
We've got a bit of variation on our plugs after the carb rebuild. This is plug 1: https://youtu.be/JvkZGn-QC-E And this is plug 3: https://youtu.be/gQVyJhMcA1c Plug 1 looks pretty lean to me. We bent the rochester monojet metering rod arm a bit to make it richer a couple of weeks ago, but I'm not seeing a difference in plug color. Will a lean plug start showing as less lean if the mixture has been corrected? Or does it get burnt permanently and should we install new plugs and run it for a while? Thanks! |
06-14-2019, 05:51 PM | #2 |
Guest
Posts: n/a
Re: Spark Plug reading
Those don’t look that abnormal by my eyes—-at least when compared to the horror show of spark plugs I have seen. In any event, plugs are cheap and I would retest with new plugs so you have an accurate baseline.
06-14-2019, 07:10 PM | #3 |
Unfortunately in these modern times of ethanol gasoline, every brand having a different mix of additives, and the change in fuel mixtures for the different seasons of the year, being able to read a spark plug with any kind of accuracy is impossible. If you were to run only straight AvGas then you would be able to read a plug like in the days of yesteryear.
On the up side of these modern times we now have wide band O2 sensors and the ability to read air/fuel ratios on a guage with far greater accuracy than what you can get by reading plugs. For example: http://67-72chevytrucks.com/vboard/s...d.php?t=713728
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-15-2019, 10:08 AM | #4 | |
06-19-2019, 10:44 PM | #5 | |
https://www.cherylyoungonline.com/Pa...her/index.html I should have mentioned in my original post that you can only only get the most basic idea of lean and rich from "reading" a spark plug. The difference between a 11:1 AFR and 16:1 AFR might be visible, but being able to discern between 13:1 and 14:1 would not be possible for most people. And since the arrival of the O2 sensor no one is bothering to learn what to look for so it truly is a lost art.
06-20-2019, 10:21 AM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Your #1 plug looks perfect, the #3 is a tic lean...I've been reading plugs for almost 50 years now and is paramount if you raced and still ride the KZ-1000 Z1's...Try a WOT plug chop test by turning off the ignition at cruise speed and rolling to a stop in neutral...Those plugs don't look bad enough to melt holes in pistons...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-14-2019, 09:31 PM | #7 |
Those look perfect and the heat range is good too.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
06-15-2019, 10:12 AM | #8 |
06-18-2019, 08:17 PM | #9 |
Lean will have some white dusting on it. Pre-detonation will have white spalding. It’s important to get the engine to temp, do a couple WoT pulls, and then read the plugs. Normal driving or a cold engine will lie to you. If you are really concerned I would buy a wide band O2 setup. It’s the definitive indicator.
