Old 09-15-2020, 07:31 PM   #1
msg
Oil filter adapter gasket and seal, where is this seal supposed to fit?
The new small block 350 I have didnt come with an oil filter adapter so I ordered the adapter, bolts and gasket and seal. The seal/o ring is bigger than the interior so I assume its supposed to sit on top of the filters seal? Whats the right way to install this seal? Or toss it?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 09-15-2020, 08:37 PM   #2
truckdude239
truckdude239's Avatar
Re: Oil filter adapter gasket and seal, where is this seal supposed to fit?
There is no seal i bolted my adapter in metal to metal that ledge is for the oil filter o-ring seals. I don't know what the ring you have is for it you don't need it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-15-2020, 09:48 PM   #3
clinebarger
That seal could be for a Oil Cooler adaptor which you don't have.
clinebarger is offline   Reply With Quote
Old 09-16-2020, 03:45 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
The only gasket for those I've ever seen looks like this, but I havnt ever used one:
Old 09-16-2020, 10:54 PM   #5
msg
Thanks for the replies fellas, I skipped the o ring seal and went ahead and used the gasket that came with my order..same one you show Rocknrod. The oil filter is now snugged up and ready for me to drop the oil in!
Old 09-17-2020, 12:23 AM   #6
clinebarger
That gasket is ALSO for a Oil Cooler Adapter & NOT required for a standard oil filter adapter!!!!
