Rim offsets? 2/4 drop
Ok so I have a 79 SWB Scottsdale, and I'm looking to put new rims on, now I'm planning on ordering a set of Eagle Alloy's 225's. However I don't really know what kind of offset I should be running and what I should be taking into consideration. (future rear disks?) I was planning on going with a 20x10 on the rear and a 20x8.5 on the front, as well I am going to have a 2/4 drop on the truck. I know I'd love the look of a 4/6 drop better but here in Canada, especially Edmonton I'd be scraping all over the place if I were that low, so I think I have to settle for the 2/4 for maximum drivability. So any suggestions would be great
Thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Rim offsets? 2/4 drop
I would run a 5" BS on the 20x8.5's.
And a 5.5" BS on the 20x10's.
Here's what's available:
PART # SIZE FINISH PATTERN OFFSET BSM CAP # LOAD SHIP WT. 2259-2012 20x10 Polished 5 on 4.5 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-2015 20x10 Polished 5 on 115mm +8 mm 5.75 3260-09 2100 lbs. lbs. 2259-2028 20x10 Polished 5 on 4.5 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-2029 20x10 Polished 5 on 4.5 +40 mm 7.00 3260-09 2100 lbs. lbs. 2259-2050 20x10 Polished 5 on 5 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-2059 20x10 Polished 5 on 135mm +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-2080 20x10 Polished 5 on 4.75 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-2081 20x10 Polished 5 on 4.75 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-2085 20x10 Polished 5 on 5 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-2812 20x8.5 Polished 5 on 4.5 -5 mm 4.50 3260-09 2100 lbs. lbs. 2259-2815 20x8.5 Polished 5 on 115mm +8 mm 5.00 3260-09 2100 lbs. lbs. 2259-2821 20x8.5 Polished 5 on 120mm +33 mm 6.00 3260-09 2100 lbs. lbs. 2259-2828 20x8.5 Polished 5 on 4.5 +8 mm 5.00 3260-09 2100 lbs. lbs. 2259-2829 20x8.5 Polished 5 on 4.5 +21 mm 5.500 3260-09 2100 lbs. lbs. 2259-2850 20x8.5 Polished 5 on 5 -5 mm 4.50 3260-09 2100 lbs. lbs. 2259-2878 20x8.5 Polished 5 on 4.75 -5 mm 4.50 3260-09 2100 lbs. lbs. 2259-2885 20x8.5 Polished 5 on 5 +8 mm 5.00 3260-09 2100 lbs. lbs. 2259-9012 18x10 Polished 5 on 4.5 -11 mm 5.00 3260-09 2100 lbs. lbs. 2259-9015 18x10 Polished 5 on 115mm +8 mm 5.75 3260-09 2100 lbs. lbs. 2259-9028 18x10 Polished 5 on 4.5 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-9029 18x10 Polished 5 on 4.5 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-9032 18x10 Polished 5 on 4.75 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-9034 18x10 Polished 5 on 4.75 -11 mm 5.00 3260-09 2100 lbs. lbs. 2259-9048 18x10 Polished 5 on 4.5 +40 mm 7.00 3260-09 2100 lbs. lbs. 2259-9050 18x10 Polished 5 on 5 -11 mm 5.00 3260-09 2100 lbs. lbs. 2259-9080 18x10 Polished 5 on 4.75 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-9082 18x10 Polished 5 on 5 +14 mm 6.00 3260-09 2100 lbs. lbs. 2259-9085 18x10 Polished 5 on 5 +2 mm 5.50 3260-09 2100 lbs. lbs. 2259-9812 18x8 Polished 5 on 4.5 +2 mm 4.50 3260-09 2100 lbs. lbs. 2259-9815 18x8 Polished 5 on 115mm +2 mm 4.50 3260-09 2100 lbs. lbs. 2259-9816 18x8 Polished 5 on 115mm +14 mm 5.00 3260-09 2100 lbs. lbs. 2259-9828 18x8 Polished 5 on 4.5 +14 mm 5.00 3260-09 2100 lbs. lbs. 2259-9829 18x8 Polished 5 on 4.5 +27 mm 5.50 3260-09 2100 lbs. lbs. 2259-9832 18x8 Polished 5 on 4.75 +27 mm 5.50 3260-09 2100 lbs. lbs. 2259-9850 18x8 Polished 5 on 5 +2 mm 4.50 3260-09 2100 lbs. lbs. 2259-9878 18x8 Polished 5 on 4.75 +2 mm 4.50 3260-09 2100 lbs. lbs. 2259-9881 18x8 Polished 5 on 4.75 +14 mm 5.00 3260-09 2100 lbs. lbs. 2259-9885 18x8 Polished 5 on 5 +14 mm 5.00 3260-09 2100 lbs. lbs.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-16-2011 at 10:18 PM. |
Well that was easy, thanks for the detailed response. I don't suppose you have a tire size off hand that you would recommend?
I personally like the 255/40-20's on the 20x8.5's.
And then a 295/40-20 on the 20x10's. That's what's on 72BlckButy's truck.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-16-2011 at 10:21 PM. |
i know this is probley posted somewhere on this site but whats the widest rim and tire i can run in the rear
Posted via Mobile Device |
