Old 06-11-2014, 05:41 PM   #1
Sklptrljay
Sklptrljay's Avatar
Help with gear ratio I.D.
Talked to a guy who has a 69 1/2 ton rear end for sale, he didn't know the gear ratio. I told him to look on the ring to find the stamped numbers, he said he doesn't see them. So he said he counted the teeth 3 times and swears it's a 43/11 which would make it a 3.91 by my calculations.
Well, I can't get over there for about a week. So just wondering, was there a stock gear ratio like this?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-11-2014, 08:42 PM   #2
Fitz
Re: Help with gear ratio I.D.
No. 3.48:1, 3.73:1, 4.11:1 only no 3.91:1 in a half ton 8.875 truck differential.
Fitz is offline   Reply With Quote
Old 06-12-2014, 01:14 AM   #3
King Cary
Rotate the right side axle 360 degrees and count how many time the pinion rotates. You will have your answer... Say it has a 3.73, the pinion will rotate 3.73 times..
King Cary is offline   Reply With Quote
Old 06-12-2014, 06:52 AM   #4
hamjet
hamjet's Avatar
It's brobably more like 41/11 which would make it 373, unless its not a half ton 8.875 diff...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
