Old 07-26-2014, 08:53 PM   #1
72MARIO
72MARIO's Avatar
AC vs Heater control Educate Me
I am just starting my installation of an old air ac kit it includes a reproduction factory a/c controller. The AC controller does not line up existing heater control holes even the angle is not correct if I was to drill holes for the AC controller. Is this just another reproduction problem? Or did heater cabsand ACcabs have different hole spacing
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-26-2014, 09:24 PM   #2
john
member #16
john's Avatar
Re: AC vs Heater control Educate Me
There is a bracket for the A/C control to fit the dash. Maybe someone has a pic.
john is offline   Reply With Quote
Old 07-26-2014, 10:56 PM   #3
72MARIO
72MARIO's Avatar
I'm a little confused as to where the 4th hose goes the first to goes to the outside outlets second goes to the other outlet the third post to the center vent should there be a 4th and on the drivers side somewhere? The defrost is split off the top of the Box. The quality of the old Air Products seems to be great the instructions definitely leave something to be desired
2005 TAHOE DD
Old 04-23-2015, 08:17 PM   #4
elf w/capital T
What did you do?
elf w/capital T is offline   Reply With Quote
