Old 01-27-2019, 11:14 PM   #1
Andy4639
Old member
Andy4639's Avatar
Ramp truck aux battery wiring
Here is how I ran my aux batteries for the winch.
I bought the cables from Harbor Frieght and ran the red one from the battery up front to my 12 volt contactor under the truck. Then the black one to the aux batteries in my case. I also have a air compressor hooked to the contactor through a relay.
The contactor is controlled by a dash mounted switch to charge the batteries and fill the tank up with a pressure switch to shut it off at 120lbs. Having the aux batteries hooked this way will not kill the truck battery for starting the truck.
But if the need arises for the aux batteries to start the truck then I can.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
