Old 11-10-2019, 06:28 PM   #1
Fbks_Cruiser
Fbks_Cruiser's Avatar
Tried to crank window down and felt a pop..
Window lowered about 1/8” before I felt the pop and the the handle just spun freely. Window didn’t go down any further. (It was cold and the window seemed hard to lower). If I turn the handle to raise the window it spins a full rotation or so then something engages and the window goes back up that 1/8”. Try to lower and handle just spins.
I can feel some things moving inside the door when turning the crank and since it does go back up a bit I know it is not just the handle spinning on the regulator.
Maybe one of the rollers broke and came out of the track? You guys think I will need to replace the whole regulator? Won’t know for sure until I get into the door, just looking for ideas from someone who knows these doors better than I do.
Btw it is a 1972.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 11-10-2019, 07:45 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Tried to crank window down and felt a pop..
Take the door panel off and inspect, All parts are available.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 11-10-2019, 07:47 PM   #3
truckster
truckster's Avatar
If the handle spins freely and then re-engages in the opposite direction you're more than likely going to need to replace the regulator. The regulator in your 72 has a longer shaft than the 69-71 units.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-11-2019, 12:16 AM   #4
Fbks_Cruiser
Yeah, that’s what I figured. I’ll have to bring it inside the garage and pull the panel. Wish I didn’t have to remove the vent window to replace the regulator. But then again, don’t need to roll the window down till spring!😁
Matt
Old 11-11-2019, 01:33 AM   #5
Astro-Balls
https://www.youtube.com/watch?v=RY3yXCjqkZE
Old 11-11-2019, 01:59 AM   #6
Fbks_Cruiser
Thanks for the link to the video. Doesn’t look like too bad of a job.
Matt
Old 11-11-2019, 11:10 AM   #7
cebra
Pro-tip: I am not a pro at all but I fought with regulators for 10 or so hours before realizing I had to enlarge the hole in the arm that the "wheel" on the regulator goes into. The wheel was bigger than OEM and it was never going to fit until I slightly enlarged the hole. I explained this like crap but you will see what I am talking about.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 11-11-2019, 05:26 PM   #8
michael bustamante
michael bustamante's Avatar
i have a 72 passenger side regulator if you need it
1967custom
michael bustamante is offline   Reply With Quote
Old 11-11-2019, 05:30 PM   #9
Fbks_Cruiser
Thanks for the offer but it is the driver side that failed.
Matt
Old 11-16-2019, 09:02 PM   #10
Fbks_Cruiser
Found the problem. Glass came out of the channel. Guess it was frozen into the weatherstrip. When I tried to crank it down I must have popped the channel off of the glass.
What is the recommended adhesive?
Matt
Old 11-16-2019, 09:15 PM   #11
Astro-Balls
Cant really see the glass, Did it come out of the U channel that had the rubber packing?
If you can push it back in, use some urethane glue to adhere it.
Old 11-16-2019, 10:39 PM   #12
Fbks_Cruiser
Yup. Came out of the U channel. Yes the packing is still in the channel. I just finished cleaning it up. Please look at these photos. Is the channel supposed to bend at the forward edge? Seems to bend down and in? I think it is not right since I can see rub marks at the bend. Also, I don’t think it will fit on the glass like that.
Also when putting the glass back in the U channel does it center fore and aft? Or is there a specific distance from the front or back edge of the glass that the channel is supposed to be?
Thanks .
Matt
Old 09-30-2020, 05:28 PM   #13
72hoopti
Did anyone ever give you the distance of where the glass was supposed to be set back into the channel? I am struggling with the same thing. Help please
72hoopti is offline   Reply With Quote
Old 09-30-2020, 05:33 PM   #14
Fbks_Cruiser
Look at post #4 in this thread:
http://67-72chevytrucks.com/vboard/s...50#post8736050
Matt
