Old 10-18-2018, 01:52 PM   #1
nobox351y
Recommendations on Dirty Dingo Low mount AC
Has anyone used the Dirty Dingo Low mount AC bracket on a swap?
Got an 87 Suburban, dont believe the stock ac compressor is going to fit with the stock mount, looking for options to keep the compressor low.
Thanks for the help and suggestions.
nobox351y is offline   Reply With Quote
Old 10-18-2018, 10:26 PM   #2
Houston Ben
Houston Ben's Avatar
Re: Recommendations on Dirty Dingo Low mount AC
I have DD upper and not happy with it. It shakes bad at idle rpm when ac clutch engaged causing the puppy to vibrate bad. I put a turnbuckle on it which helped some. Don’t know about their lower.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 10-19-2018, 08:11 AM   #3
nobox351y
Houston: What motor mounts did you use and why did you choose to move the AC compressor? I have the cheap adjustable conversion mounts set to put the engine in the stock location, Fairly certain the compressor is going to hit the mount and or stand.
Old 10-19-2018, 11:31 AM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
My 87 silverado used the stock 5.3 compressor and brackets no prob, standard motor mounts plates, stock mounts
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-21-2018, 09:49 AM   #5
Wgesnerjr
Wgesnerjr's Avatar
a/c Is my springtime project. Please post pics. I am in research mode.
thanks.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 10-21-2018, 10:37 AM   #6
sweetk30
sweetk30's Avatar
nice to know i am not the only one unhappy with his products and customer service attitude .
he screwed me over a few years ago on motor mounts .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-21-2018, 06:41 PM   #7
sprint_9
sprint_9's Avatar
I tried and sent back the DD low mount, the one I had would not square the compressor to the rest of the belt drive.
After that I went with the Holley low mount, it is much nicer. Built better and more importantly mounts everything square.
sprint_9 is offline   Reply With Quote
Old 10-22-2018, 01:37 PM   #8
nobox351y
I used the ICT billet adapter mounts. That style of mount prevents you from being able to use the stock ac mount.
87chevy, got any pics?
Old 10-23-2018, 02:05 PM   #9
87chevy.com
Pic of it installed? I don't have that engine combo installed anymore, upgraded.
Old 10-24-2018, 10:41 AM   #10
nobox351y
Yea, I was just hoping to see how the motor mounts and the ac mount looked next to one another.
Probably too late now though as I have everything back in and wont be changing the mounts.
