Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-07-2021, 12:43 PM   #1
roll_the_dice
roll_the_dice's Avatar
FS--Gauge cluster wiring harnesses
I have 5 full wiring harnesses for clusters...these are all for clusters with gauges, not warning lights. $30 each shipped
I also have 1 harness missing the 2 main dash connections $20 shipped
Picture of the 5 harnesses and the single picture is the one missing 2 connectors.
roll_the_dice is offline   Reply With Quote
Old 01-09-2021, 01:41 AM   #2
aotte1
Re: FS--Gauge cluster wiring harnesses
I will take the 2 best please, for 66’ gauge clusters.
Payment information.
aotte1 is offline   Reply With Quote
Old 01-09-2021, 10:34 AM   #3
roll_the_dice
Paypal info sent via PM. Thanks
2 sold to aotte1--Thanks
Old 01-18-2021, 11:19 PM   #4
roll_the_dice
bump
Old 02-03-2021, 05:03 PM   #5
roll_the_dice
Bump 3 left at $30 and 1 at $20 (see description above)... all 4 for $90 shipped
Old 02-06-2021, 04:46 PM   #6
southern parts
southern parts's Avatar
Will these work on 60 - 63 clusters too?
southern parts is offline   Reply With Quote
Old 02-06-2021, 05:28 PM   #7
roll_the_dice
I think they will work, but just not 100% sure to be honest. When I look at the schematic from AAW the wiring harness or a 60-61 is the same as the 64-66...the only difference I see in 62-63 is that it says it has one turn signal not 2?
https://smhttp-ssl-87263.nexcesscdn....608_IN_4.0.pdf
Old 02-24-2021, 08:13 PM   #8
roll_the_dice
bump
Old 02-25-2021, 10:07 AM   #9
tchevs
Im interested, how would you describe the condition on these?
tchevs is offline   Reply With Quote
Old 02-25-2021, 10:16 AM   #10
roll_the_dice
I've got 3 that are in really good condition. No frayed ends, just need to be cleaned up if you wanted to. $30 each shipped
I have 1 that one of the main harness plugs is showing signs of melting...and looks like someone spliced a new bulb wire in. $20 shipped
I have 1 that the main 2 harness plugs were cut off, but there is enough wiring left to graft in new harnesses plugs with a few inches of wire between plug and harness. $20 shipped
$110 for all 5 shipped
I think they are all good candidates for cleaning and restoring a harness to factory spec. The first 3 are by far the best...since I am confident they would work as is. The other 2 need some work.
Old 02-26-2021, 10:04 AM   #11
tchevs
I just noticed the question from southern parts. Mine is an early truck, I woudnt mind doing the extra work to get it to work on mine if you can do $25 on one of your good ones. If you cannot I understand.
Old 02-26-2021, 02:30 PM   #12
roll_the_dice
PM Sent. Not trying to kill anyone on these...so if you have to modify it I will take $25.
Old 02-27-2021, 09:42 PM   #13
tchevs
Payment sent, thank you
Old 02-27-2021, 10:00 PM   #14
roll_the_dice
Thanks...got it. Will send you tracking when it ships Monday.
This is what I have left...
I've got 2 left that are in really good condition. No frayed ends, just need to be cleaned up if you wanted to. $30 each shipped
$90 for all 4 shipped
I think they are all good candidates for cleaning and restoring a harness to factory spec. The first 2 are by far the best...since I am confident they would work as is. The other 2 need some work.
Old 03-05-2021, 09:49 AM   #15
tchevs
received my harness, thank you
Old 03-15-2021, 01:41 PM   #16
Jeepnut
Jeepnut's Avatar
I will take one of the $30 ones please, thank you
Jeepnut is offline   Reply With Quote
Old 03-15-2021, 01:47 PM   #17
roll_the_dice
PM Sent. Thanks!
Old 03-16-2021, 02:22 PM   #18
roll_the_dice
Boxed and label printed....shipping tomorrow USPS 9400128206334252431971
Old 03-18-2021, 09:36 AM   #19
roll_the_dice
I've got 1 left that is in really good condition. No frayed ends, just need to be cleaned up if you wanted to. $30 shipped
$60 for all 3 shipped
