Old 12-22-2009, 03:45 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Cummins 6BT Swap
i have been think about it and have found a import place here where i almost can get them thown at me the are from marine and semies
my truck has a stock 6.2 Non turbo with only 79xxx miles on it
run sweet
would i get anything by replacing it with a cummins 6bt or am i better of with the 6.2 and add a turbo to it
what im looking for is not HP but lb-tq and Millage
i would really like some imput on this to or not to do
its a Chevy C-30 Crew Cab 1 Ton Dually 1984
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 12-22-2009, 04:13 PM   #2
munger
munger's Avatar
Re: Cummins 6BT Swap
ya the 6bt is rated at 302 hp and in the range of 500-600lb tq so it would be doubling the 6.2s power while taking of 2 cylinders
if you do find one with a tranny behind it its easier that way
mitch
87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s
munger is offline   Reply With Quote
Old 12-22-2009, 04:46 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I love GM trucks. Period. BUT, if I had the oppertunity I would swap the 6.2 out for a 6BT. You would be silly not to. The 6BT is a million times better than the 6.2 If anyone telly you otherwise it is because they have not owned both and dont really know the difference.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-22-2009, 05:11 PM   #4
78-5.3
78-5.3's Avatar
1000 lbs of motor and very tall engine i was going this route but decided against it !
78-5.3 is offline   Reply With Quote
Old 12-22-2009, 05:13 PM   #5
78-5.3
78-5.3's Avatar
yeah the adapters behind the wonder bread vans are not very good there on an angle!!!
Old 12-22-2009, 05:17 PM   #6
GmtGmt
GmtGmt's Avatar
Here is one i have been looking at
this is alost a copy of what i have in mind for my own
what kind of tranny would you guys recound for me if i do a swap like this would i be able to use the clutch, bellhousing and tranny from my 6.2? tranny is a SM465
Thomas
Old 12-22-2009, 05:57 PM   #7
munger
munger's Avatar
no you wouldnt be able to use your bellhousing but the th tranny you could just different clutch and bellhousing find one with a nv4500 behind it
mitch
Old 12-22-2009, 06:58 PM   #8
Prerunner1982
Prerunner1982's Avatar
How about a 4-71 Detroit, supercharged, turbocharged, and intercooled backed by a Roadranger 13 speed trans?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-22-2009, 08:11 PM   #9
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
ok pre runner that is a tease. i need to see more pics.
BIGCHEVYMAN is offline   Reply With Quote
Old 12-22-2009, 08:36 PM   #10
Thealien
Thealien's Avatar
I couldn't agree more!
Old 12-22-2009, 08:46 PM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Diesels rock
http://forum.neow.net/index.php?show...862&hl=cummins
If it can fit in a S10 why not your truck!
Search Youtube. You'll find some great 6BT videos.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-22-2009, 09:50 PM   #12
clinebarger
You can use a NV4500 5spd or a NV5600 6spd from a Cummins powered dodge, the autos too exept the 07.5 and up aisin & dodge trans. I say go with a Cummins, milage is just as good with better power & no glow plugs to deal with, better injection pump, & they go 700,000 miles easy (i dont know what that whould be in KM)
clinebarger is offline   Reply With Quote
Old 12-23-2009, 04:19 AM   #13
GmtGmt
GmtGmt's Avatar
can i get a little more info on this
woundering if a Detroit 6V53 would fit
Thomas
Old 12-23-2009, 10:10 AM   #14
Prerunner1982
He is a member here as well but not very active. His user name is Aramp1.
Here is his build thread on ColoradoK5. http://coloradok5.com/forums/showthread.php?t=212269
But I will post a few more pics.
I have always liked his truck... but it just keeps getting better and better.
Jon
Oklahoma Roll Call
Old 12-23-2009, 11:44 AM   #15
Chevyman350
Your best bet is to get a Complete cummmins dodge manual drive traind and convert your truck to hydraulic clutch (87 and up) had hydraulic. You will loce the Overdrive from the NV4500.
This route will also be the least expensive as the adapters are quite expensive.
There are places that sell the mounts ( http://www.autoworldmt.com/ )
The stock power will be far beyond the 6.2 will ever be capable of modified.
The 94-98 12V have hydraulic clutch, I am not sure about the 1989-1993 12V.
Chevyman350 is offline   Reply With Quote
Old 12-23-2009, 12:00 PM   #16
Thealien
Thealien's Avatar
Thanks, Thought I had seen that before.
Old 12-23-2009, 12:19 PM   #17
nekkidhillbilly
4btswaps.com has all the info on this looking to do the same thing
2004 2500 hd dmax cc 4x4
2008 saturn aura xr
1966 buick gran sport
1984 k20
nekkidhillbilly is offline   Reply With Quote
Old 12-23-2009, 11:35 PM   #18
munger
munger's Avatar
here ya go http://denver.craigslist.org/pts/1507988111.html
mitch
Old 11-30-2010, 05:38 PM   #19
legendary
legendary's Avatar
did you ever take the plunge?
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 11-30-2010, 06:11 PM   #20
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
Why would someone want to waste a truck on a 2-stroke Detroit?
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 02-20-2021, 09:40 AM   #21
Ford Assassin
Ford Assassin's Avatar
The 1st gen 89-93 Dodge Cummins also used a hydraulic clutch, but used the weaker Getrag transmission. Dodge didn't start using the nv4500 until the 2nd Gen in 1994.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
