Old 06-15-2019, 12:44 PM   #1
naphtali5725
naphtali5725's Avatar
CPP 73-87 brake booster combo question
hey all, i have an 86 1/2 ton. i want to replace the brake booster/MC/PV on my truck because i switched from the JB3 code to JB5 code hardware (drums/rotors/calipers/wheel cylinders)
my question is. will this CPP combo work for my truck?
cpp part number 7387BB-MC
https://www.summitracing.com/parts/clp-7387bb-mc
called their tech line, they said it is an 11 inch single diaphragm...
or should i just buy the factory parts?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 06-15-2019, 01:19 PM   #2
Bloodhound
Re: CPP 73-87 brake booster combo question
I just installed that on my 1981 C10. I'm a ways from driving it but the quality appears to be really good. I believe it would work well with the JB5 brakes.
Bloodhound is offline   Reply With Quote
Old 06-15-2019, 01:20 PM   #3
WyattTX
It will likely work, but you may have to adjust the pushrod in the booster, otherwise your pedal may be soft when the engine is running.
WyattTX is offline   Reply With Quote
Old 06-15-2019, 01:56 PM   #4
naphtali5725
my concern was the JB3 brakes have a single diaphragm booster, JB5 has a dual diaphragm booster...
since this is aftermarket, i was looking for some feedback from someone who has used in this scenario..., if this one, being a single diaphragm, is it equal to a dual as far as power is concerned?
My build thread...
Disabled Veteran
Old 06-15-2019, 09:41 PM   #5
naphtali5725
went ahead and ordered factory replacement BB and MC from rockauto
My build thread...
Disabled Veteran
Old 06-15-2019, 09:55 PM   #6
WyattTX
Good luck, and dont forget to bleed the master cylinder too.
Old 06-17-2019, 02:08 PM   #7
demian5
demian5's Avatar
BEFORE you install it in the truck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-17-2019, 06:43 PM   #8
sweetk30
sweetk30's Avatar
do NOT bench bleed them with the stupid plugs they give you now a days . get a hose kit or make your own from 2 hard lines and a extra set of hard line nuts .
i did one with the plugs and it never felt right clamped in the bench vise using a long screw driver to plung it . took them out and did the hard lines i had ( had to go looking for them ) and the unit belched so much air it wasnt funny . felt super after this . installed and bleed system good to go .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-17-2019, 09:54 PM   #9
WyattTX
Are the plastic nipple, and hose bench bleed kits from the parts store any good, or should I make some hard lines like yours? I may be replacing a master cylinder myself soon.
Old 06-17-2019, 11:29 PM   #10
sweetk30
sweetk30's Avatar
just dont use the solid cap plugs . most any hose kit or if you do a few more than the average guy then i like hard line .
