Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-19-2019, 08:41 PM   #1
yuccales
yuccales's Avatar
Connector pins
I've looked at the thousands of pins out there and cannot find these or what their names are. I need 5 but will get more due to clumsy fingers. They look to be crimp on. The plug can be reused, but if I could order pin/plug combo that would be great. If any of you could steer me in the right direction it would be much appreciated. Thanks
yuccales is offline   Reply With Quote
Old 10-19-2019, 08:58 PM   #2
Killer Bee
Killer Bee's Avatar
Re: Connector pins
that particular connector shell does not look familiar to me.. amp, molex, metripak??
what application is it? based on the industry the connector belongs to, tried any vendors that carry the major components?
just out of the blue, could browse a catalog like Mousers or Newark..
or email JK Electronics with a picture and they probably could ID the brand..
good luck!
Old 10-19-2019, 09:07 PM   #3
yuccales
yuccales's Avatar
Re: Connector pins
good luck!
It is from a marquee light in a bus. The opening/closing of a door broke all the wires. I don't have the faintest idea who the maker is, however I'm going to check out the JK electronics site you showed. Thank you for the ideas. Sure wish some old school Radio Shack stores were still around.
Old 10-20-2019, 12:44 AM   #4
dmjlambert
dmjlambert's Avatar
Re: Connector pins
If you have no luck finding it, you may be able to pry the crimp connections apart, remove the old wire, and lay a wire in there and solder it, so you re-use the pins.
