Old 01-24-2007, 08:08 PM   #1
1969k10stepside
Arrow Difference between 4x4 and 2wd frames-Look here
I see this asked alot,I have pics comparing the two frames and Im gonna share them for people to see the difference.
First pic is a lwb 2wd frame on my old 71 c/10.Second and third are of my 69 4x4 frame two years ago when I got it.I am gonna add pics of my swb 4x4 frame shortly also for better pics
Name:  71 c10 frame.jpg
Name:  69 4x4 frame.jpg
1969k10stepside is offline   Reply With Quote
Old 01-24-2007, 08:10 PM   #2
1969k10stepside
Re: Difference between 4x4 and 2wd frames-Look here
The 2wd has a noticeable difference in the back of the frame for the coils as to the straight 4x4 frame for the 52"(56" for 67-68) leaf springs.
Old 01-24-2007, 08:48 PM   #3
Terraizer
What about the differences up front? My 1971 C-20 has leafs just like the 4x4 you show not the coils. I know up front the front cross member will be different but what about the frame rails themselves inf ront of the cab?
1971 Chevy C-20 2x4 Grandpas old truck soon to be 4wheeldrive
Terraizer is offline   Reply With Quote
Old 01-24-2007, 10:07 PM   #4
1969k10stepside
I am not sure on the front.I know the 4x4s have the brackets for the bushings and shackels for the front springs,and under the rad. mounts there is a riveted bracket for the front spring hanger.I dont know how you can convert it for that
Old 01-24-2007, 11:18 PM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Front's not hard to convert on a c10 if you get all the brackets, just drill for the extra holes and bolt on with proper size grade 8's. Ya do have to flatten or cut out the dimpled out places where the e brake cable and holder goes.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 10-20-2019, 12:10 AM   #6
HarleyHogRider
I so want to thank you for this post on the difference in frames. I have spent hours and hours trying to convince Classic Performance Products (C-Notch Kits 6372CNK-HD) and McGaughy's (C-Section Kits 63167) both of which I ordered through Summit that their claims that these fit every Chevy and GMC truck from 67-72 was false advertisement and that they only fit Coil Spring Truck frames not Leaf Spring Frames. They do not fit GMC frames with leaf springs. I finally wound up fabricating my own C-Notch's for my 70 GMC 3/4 ton C-2500 frame. So frustrating ordering stuff they claim will fit and it doesn't. I finally discovered the same difference you did in your post. VERY, VERY Valuable information to put out there. I converted my 3/4 ton C-2500 GMC to a Chevy C-10 suspension in the front and rear to get the fancier wheels in a 5 lug and not an 8 lug. (1000 HP, 540 CI, Vortech V7, Abruzzi TH 400, Strange Engineering Ford 9 inch, converted to Coil Overs)
HarleyHogRider is offline   Reply With Quote
Old 10-20-2019, 08:54 AM   #7
palallin
Is this 2wd vs 4wd or coil vs leaf?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-20-2019, 10:15 AM   #8
More like coil 2wd vs 4wd. The 2wd leaf spring frames don't bubble out like the coil spring ones do, but they have a taper behind the axle that 4wd frames don't. We need a picture of a leaf spring 2wd to complete this thread.
I know in the front hump in the frame, over the front wheels, the 4wd frame rises about 1" more. But this makes no difference when doing a 2wd to 4wd conversion.
All other dimensions are the same, so all the 4wd components fully swap to a 2wd frame.
Suburban frames only differ from LWB pickups in some body mounting brackets. I wish I had gotten copies. But when a friend wanted to put a 4wd chassis under a Panel truck he came up with diagrams with all the specs for these GM light trucks and these are things we found out. It was years ago and I never checked on actual vehicles, but these were GM drawings. He ended up donating a 4wd Suburban to complete the project
Old 10-20-2019, 11:03 PM   #9
HarleyHogRider
_________________
Not sure if your post is a question because of my post. But this thread started out as Re: Difference between 4x4 and 2wd frames-Look here
Mine is a 2wd frame and I was attempting to show the difference between two different kinds of 2wd frames. That is, the difference between leaf and coil 2wd frames which are also different than 4wd frames.
Old 10-21-2019, 12:20 AM   #10
chewychevy67
This is my 67 swb 2wd leaf spring frame.
chewychevy67 is online now   Reply With Quote
Old 10-21-2019, 01:15 AM   #11
Bob B.
My '67 GMC C-2500 frame is similar but longer than chewychevy67's. special-K is right, the 4X2 leaf spring frames are contoured towards the rear, not straight like the 4X4's
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 10-21-2019, 10:27 AM   #12
57taskforce
All about them K’s
57taskforce's Avatar
It’s Also probably worth noting that the 2wd frames have ebrake cables and holes right where the rear front spring spring hanger goes. The holes have to be filled with plate and then the correct holes drilled for the hanger when converting a 2wd to 4x4.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
