10-12-2018, 12:41 AM | #1 |
Suburban. Don’t know year
Are these Suburbans very common? I was sent these pics by a friend. I was expecting a 1973 4wd but this is an older what appears to be 2wd. Interesting.
Posted via Mobile Device |
10-12-2018, 01:09 AM | #2 |
Re: Suburban. Don’t know year
I'd jump on it if I was looking for a project.
I have a '67 K/10 Suburban that I need to rebuild already. As far as 'rare' -- I've seen literature stating that only ~166 K/10 [4WD, Half ton] Suburbans were produced in Model Year 1967. Numbers would increase as the production run progressed. Mine had a 454 a PO had shoehorned in. It would pass anything on the road but a gas station. The 'Barn Doors' are desirable, but I like the lift/tailgate myself. Tailgates are handy for a small gas grill BBQ. Body appears straight. Dings are not major. Looks like a '68 C/1500, judging by the presence of side reflector markers and the angle of the leading edge of the hood. The 3-door set up was only made during the 67-72 run. Any 4-door Subs of the period were custom jobs. [Once saw one in a parking lot ... the guy had faked-in a Door #4, with a phoney outside door handle and painted-on door lines.] Being a GMC is a plus, they were higher optioned usually. Looks repainted in yellow. Was it a school bus in a small community once? Cool find. Could be a fun project. Good luck.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-12-2018 at 01:20 AM. |
10-12-2018, 10:16 AM | #3 |
Slant nose with marker lights. It should be a 1968.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-12-2018, 04:33 PM | #4 | |
I was told it was owned by a school. Correct. Can be had pretty reasonably under 500 I think but I prefer 4wd. I think 6 cyl. Thanks. Posted via Mobile Device |
10-12-2018, 07:21 PM | #5 | |
To make a C truck into a K truck, you pretty much have to find the 4x4 frame and swap the body over. Four wheel drive Subs were rare. I think the Suburban's 127'' wheelbase was in common with longbed fleetside pickups, but I'm not positive. With a front winch and a positraction rearend, it would probably go anywhere. I'd go for it.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-19-2018 at 12:43 PM. Reason: correction |
10-19-2018, 09:15 AM | #6 |
Just find a 4x4 chassis and take all the bracketed and put it on that frame, GM was smart for the most part and already drilled all the wholes to make a truck either 4x4 or 2wd, just mattered what they bolted on. Pickup chassis are a little different for the body mounting. They are the same 127 in wheel base but the curves and mounting bracketry are different.
10-20-2018, 06:55 AM | #7 |
What’s the interior like?
