02-07-2011, 03:17 AM | #1 |
60-66 Nut
Re: '62 BBW SWB Highschool ride returns
That door looks real nice
I can identify with your situation. Sometimes a guy has to work on something that isn't quite so overwhelming. Then it is a little easier to achieve a sense of accomplishment. Not that big projects are bad, it's just that sometimes a guy needs a break from them.
02-07-2011, 01:10 PM | #2 | |
Anyways here's more pics: Here's what I started with. And here it is after the Acid Etch Primer. There were 16 holes from the mirrors this thing has had thru its life. The three original had been brazed shut sometime before I got it. Since I'm gonna go back to stock mirrors, I drilled & tapped those, and will put a washer & nut on the backside. The other holes got welded shut, and ground down, with a skim coat of Rage Gold over them. |
