Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-18-2017, 11:48 AM   #1
demian5
demian5's Avatar
70 GMC parking lights in grill don't come on
On my 1970 GMC, the parking lights in grill don't come on, the turn signals work fine, the side markers work fine, but the parking lights in grill do not come on in any switch position.
Maybe these don't have parking lights there?
I don't have a WD to check against.
Thanks!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-18-2017, 12:06 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 70 GMC parking lights in grill don't come on
Look and see if they are double element bulbs. If they are then something isn't working. If the are single elements then your correct.
According to this post you should have park lights also.
http://67-72chevytrucks.com/vboard/s...d.php?t=596540
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2017, 12:22 PM   #3
demian5
demian5's Avatar
Thanks - I'll check it out. Id like to have them work, but that would require a harness change I imagine.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-19-2017, 12:16 AM   #4
saxart
saxart's Avatar
I had a similar situation in my 70 Chev. I had to run extra ground wires to those lights. I made a "pig tail" which was a wire with a ring terminal on both ends. One end went under the head of one of the light's mounting bolts. I found an original hole in the radiator support. That's where I put the other one with the help of an extra bolt.
Try touching a scrap of wire by hand to see if that fixes it temporarily.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 01-19-2017, 06:59 AM   #5
Andy4639
Old member
Andy4639's Avatar
The front parking lights should be running lights and turn signal's both. Side markers will only be running lights. They didn't start having the turn signal's until 71.
Old 01-19-2017, 08:58 AM   #6
midniteblues
midniteblues's Avatar
Just to elaborate on Andy suggestion only cause someone could've put in the only bulbs they had.
Pull a bulb.
there should be two contacts in the bottom of the socket.
And two contacts on the bottom of the bulb.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-19-2017, 09:31 AM   #7
rockyrivermark
get a tester and see if you have power at the plug, check with a different ground and islolate the problem to the plug conntection, bulb, or ground. if those check out and it still doesn't work you can run a new hot wire off the headlight switch.
I'm guessing you won't have to do that though.
prob ground issue.
changing electrical problems is a game of elimination.
Mark
rockyrivermark is offline   Reply With Quote
Old 01-19-2017, 03:05 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If the turn signals are working I would guess that grounds are not the problem especiallly when both lights aren't working.
The parking lights are fed by a purple wire straight from the headlight switch which starts as a brown wire and runs to the firewall block where it connects with the purple wire that goes to the parking lights. I would pull the socket plug off the left light cause it's easy to get to and jump from the battery positive to the purple wire terminal and see if the right light comes on. If it does then there is a power problem not a ground problem.
follow the purple wires back to the firewall block. On the inside of the cab they connect to the brown wire that runs to the head light switch.
Name:  HEI and stock wiring..jpg
Have you checked to see if the bulbs are good?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-22-2017, 11:26 AM   #9
demian5
demian5's Avatar
Turned out my parking bulbs were burned out (D'oh).
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-22-2017, 11:37 AM   #10
davepl
davepl's Avatar
Like the saying goes, when you see hoofprints, think horses, not zebras!
Sometimes it's the simple solution :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
