Old 03-23-2021, 06:30 PM   #1
royr
Removing Jimmy Emblem.
Any tricks to removing the emblems without having to unbolt outer/inner fenders? Thanks
royr is offline   Reply With Quote
Old 03-25-2021, 07:31 PM   #2
truckster
truckster's Avatar
Re: Removing Jimmy Emblem.
I'll jump in here since you haven't received any responses yet. Having just put my front clip back together, I really can't see any way you could do that without at least removing the inner fender. Even then it would take a lot of flexibility and patience.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-25-2021, 08:53 PM   #3
royr
Appreciate the feedback.
Do you happen to know if the reproduced Jimmy emblems are plastic or metal?
Old 03-25-2021, 11:51 PM   #4
Blazerowner
Blazerowner's Avatar
I’ve done it with the inner fender in. Not easy but doable.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 03-25-2021, 11:57 PM   #5
royr
Unbolt the lower fender?
Old 03-26-2021, 01:23 AM   #6
Blazerowner
I don’t think I did. You have to use a small wrench and basically lay across the fender. If I did it again the inner fenders would come out. It’s a pain.
Kirk
66 Nova
Old 03-26-2021, 11:34 AM   #7
truckster
truckster's Avatar
Mine is a Blazer, so I can't say for sure, but the ones I got are nice, heavy metal.
Old 03-26-2021, 12:13 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
I have done it from underneath the rear edge of the fender. You will need patience, and a longer 3/8ths ratchet wrench, and long arms.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-26-2021, 12:17 PM   #9
royr
Thanks, Mark at motorcityk5 said the same, but couldn't confirm on the Jimmy ones.
Old 03-26-2021, 12:21 PM   #10
royr
Thanks! And allot of cuss words I suspect If I can confirm that the reproduced ones are metal, I'll probably just cut the studs on mine. They need to be repainted anyway.
Old 04-04-2021, 09:55 PM   #11
Ptjsk
Don't cut the originals if you can help it.
I have yet to see, or have a reproduction item as good as the originals.
Pat
Ptjsk is offline   Reply With Quote
Old 04-04-2021, 11:45 PM   #12
royr
Pat
Point well taken. It would be headed for paint for a few months so have time to decide.
