Old 12-17-2017, 07:03 PM   #1
turbojamie
700r4 starter question
Hey guys my first post on here. I need some help, I have a 67 c10 stock 283. Was a 3 on the tree. I purchased a 700r4 from monster. So far everything has went smooth. I went to parts store and bought a starter for an automatic truck they gave me part number R713240B I get it home it doesn't fit, the outside hits the flexplate. My question is what starter do I need or did they give me the wrong starter? I have a 168 tooth flexplate if that makes a difference. Thanks in advance.
Jamie
turbojamie is offline   Reply With Quote
Old 12-17-2017, 07:15 PM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: 700r4 starter question
Lots of different starters out there. The nose of the starter is the problem I'm guessing. Ran into this on my camaro. Took the starter that came with my car to a shop that rebuilds them. When it came time to install it same problem. Luckily enough I figured out what nose I needed and they looked around in there shop and found one. Cost an extra 20.00 but I was glad I didn't have to start over with a complete different starter
Jcfcamaro is offline   Reply With Quote
Old 12-17-2017, 07:19 PM   #3
harpo231
harpo231's Avatar
Should work if using same housing and 168 tooth wheel
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-17-2017, 07:22 PM   #4
turbojamie
Yes your right the nose is hitting the flywheel
Old 12-17-2017, 07:24 PM   #5
turbojamie
Not sure what you mean same housing and flywheel. This was a manual im putting a 700r4 in
Old 12-17-2017, 11:02 PM   #6
Shinysideup
Shinysideup's Avatar
Simple, you were given a stater for a 153 tooth flexplate. Get a proper hi-torque unit for a 168 tooth. Notice the staggered mounting holes,your oreily unit has them straight across.
I believe this one is correct for you. ACDELCO 3371016
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 12-17-2017, 11:04 PM   #7
turbojamie
Yes sir u are correct, I just stumbled across this like 15 minutes ago. I need a starter with the stargered bolt holes
Old 12-17-2017, 11:33 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
ACDELCO Part # 3371022 one of these will work great
