01-28-2013, 01:09 PM | #176 | |
Re: Project 69SWB
Posted via Mobile Device |
01-28-2013, 01:12 PM | #177 |
67cheby
Re: Project 69SWB
nice metal work !
01-28-2013, 02:10 PM | #178 |
Re: Project 69SWB
Thanks a bunch Mike. You've been down this road before huh?
01-28-2013, 07:26 PM | #179 |
Re: Project 69SWB
Well I was off work today so I decided to chop up the drivers side and see what I had in store for me. Pretty much the same as the passenger side, but I won't be replacing the upper cab corner. Time to order some repair parts. I already have the rocker and cab corner, but looks like I will need the inner rocker, front and rear patch pieces for the pillars, and the front piece for the floor. The supports underneath look ok and I didn't worry about supporting the pillar before cutting all this out. It's not really necessary as I found out on the passenger side. Here's some pics of the nasty.
01-28-2013, 08:41 PM | #180 | |
Re: Project 69SWB
Lookin forward to seein some more great sheetmetal repair!
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** |
01-28-2013, 09:05 PM | #181 | |
Re: Project 69SWB
02-05-2013, 10:49 PM | #182 |
Re: Project 69SWB
Have some serious metal skillz
02-06-2013, 11:10 AM | #183 |
Re: Project 69SWB
Thanks Bomp! .. after skimming through your build thread.. That is a GREAT compliment coming from you. You have no fear! I'm subscribed.
I'm about done with the drivers side on this.. will post pics soon. |
02-18-2013, 12:25 PM | #184 |
Re: Project 69SWB
Finally got around to finishing up the drivers side. I had made a crucial mistake by welding in the rocker without checking it against a hung door... man I won't do that again EVER. So I had to cut the rocker back out and redo it... I was able to salvage it, but it took some delicate surgical cutting to get it out without ruining it. Thankfully I had not welded it to the inner rocker/floor piece. I knew better, but just got in a hurry. Anyway.. I replaced both pillar bottoms, part of the floor, part of the inner rocker, kick panel, rocker and cab corner for this side. I have one small repair to the top of the drivers door seal left and another small repair to the roof, then I'm going to move on to doing the undercoat on the floor, still haven't decided what to use on that yet.. bedliner or actual undercoating.
02-18-2013, 12:29 PM | #185 |
Re: Project 69SWB
PS. That's you're corner/contribution Scott! Thanks again!
02-18-2013, 12:45 PM | #186 |
Re: Project 69SWB
Looks great Jimmy, like brand new.
Scott |
02-18-2013, 07:31 PM | #187 | |
Re: Project 69SWB
02-18-2013, 07:40 PM | #188 |
Re: Project 69SWB
Thanks for the solidarity brother!
02-18-2013, 07:51 PM | #189 |
Re: Project 69SWB
lookin good !!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
02-26-2013, 10:47 PM | #190 |
Re: Project 69SWB
Thank you!
I finally got to the underneath of the cab and have a little cleaning up to do, but should get it covered this weekend. I decided to go ahead and go with Herculiner instead of trying something else, I've used it on a couple different Jeep tubs and I just can't imagine anything holding up better than it has. Here's where the cab is now. Little grinding to do, then I can spray the Herc. |
02-27-2013, 12:03 AM | #191 |
Re: Project 69SWB
Hey! Lookin good Jimmy!! Almost didnt recognize your build with the new name.
1970 SWB Build |
02-27-2013, 08:56 AM | #192 |
Re: Project 69SWB
Metalwork looks great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-27-2013, 10:12 AM | #193 | |
Re: Project 69SWB
Thank you Low Elco... What as great find on that little black truck link in your sig. |
02-27-2013, 10:35 AM | #194 |
Re: Project 69SWB
Thanks! It's a bucket, but it's my paid for bucket!
03-03-2013, 06:46 PM | #195 |
Re: Project 69SWB
The undercoating is done.
Here's all the stuff I used. First I washed it all up with some Eastwood Fast Etch & Metal Prep and then used Eastewood's PRE to wipe it down. I let it all soak into the seams and air dry with a fan on it overnight. I then used 3M Seam Sealer and sealed up anywhere I had done welding or had gaps. I also welded up the gas line holes.... so it's now official -- I won't be putting a tank back into the cab. :-) After the Prep & PRE Last edited by ~Whitey~; 03-03-2013 at 07:05 PM. |
03-03-2013, 06:52 PM | #196 |
Re: Project 69SWB
I stuff cotton into all the holes where bolts went so I didn't accidentally get Herculiner into them then I laid down the first coat with a brush because I wanted to make sure I had enough Herculiner and also that I was able to get it into places the spray gun wouldn't fit. Also I broke out my headlamp so I could make absolute sure I was getting good coverage while doing the brush coat.
Total I used 2 quarts... The brush coat took just under a quart. The sprayed coat could have taken less, but I just went ahead and used it all up. I just went at it in sections.. DAB DAB BRUSH BRUSH STIR STIR REPEAT! Last edited by ~Whitey~; 03-03-2013 at 07:02 PM. |
03-03-2013, 06:55 PM | #197 |
Re: Project 69SWB
I couldn't be happier with how it turned out. I've used Herculiner on a couple Jeep tubs before and knew it was a good product. The texture came out great in the spray coat using the Harbor Freight texture gun, the smallest nozzle, no thinning, and the compressor on 35psi... I let 2 hours elapse in between coats.
I still have to spray the UV protection.. I'll post another pic after that... Got bored waiting, so here I am. Have to let it all dry a few hours before I can do that. Last edited by ~Whitey~; 03-03-2013 at 07:08 PM. |
03-03-2013, 08:10 PM | #198 |
Re: Project 69SWB
looks great
Rob |
03-03-2013, 09:00 PM | #199 |
Re: Project 69SWB
Wow man that came out really nice, that wont be rusting again for a long long time.
A suggestion if I may, I noticed you are using a UV topcoat, since it will never see any sun you might want to use a less expensive product on that part, and save the UV topcoat for another application. |
03-03-2013, 09:10 PM | #200 |
Re: Project 69SWB
Cab turned out great! awesome job replacing the whole corner of the cab. If you don't mind how exactly did you get the cab up on its back? I have a few ideas in my head but getting a few other opinions on methods before I do it.
I am concerned that someone stole your identity and changed your name Keep up the great work!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 03-03-2013 at 09:10 PM. Reason: grammar |
Tags |
1969, black, custom 10, fleetside, shortbed |
