04-10-2020, 01:54 PM | #1 |
Help with TDC
I never worked on the engine since buying my truck a few years back. So i wanted to rebuild my carburetor throw on the new ram horns i have along with exhaust system and new HEI. I want to clean up the intake manifold and replace the gasket while i can get at it. I'm trying to find TDC...here's my issue. When both rockers on #1 cylinder closed my rotor button is pointing to #2 cylinder and the timing mark on the balancer is no where near the mark? The only thing i can think is someone changed the timing chain and was off and just compensated instead of redoing it?? Any help would be appreciated What are my options to remove the distributor do the work and get it back together and running?
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
04-10-2020, 03:22 PM | #2 |
Re: Help with TDC
04-10-2020, 03:25 PM | #3 | |
Re: Help with TDC
04-10-2020, 03:31 PM | #4 |
Post Whore
Re: Help with TDC
Another reason the timing marks would be off is if the outer ring of the balancer has spun in relation to the inner hub. It is not uncommon for the rubber bonding the two pieces to fail. Most of the time a wobble is noticeable when the engine is running, but not always.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-10-2020, 03:35 PM | #5 |
Re: Help with TDC
thanks gents. With someone else turning the crank I was able to see the piston come up in the spark plug hole. It did line up on the timing mark to balancer mark. Rotor button was pointing to the #7 piston. At least I know I'm at TDC and will start from there when i install the new HEI.
04-10-2020, 03:47 PM | #6 |
Re: Help with TDC
Make sure your piston is up on the compression stroke. Search Youtube for finding TDC. There are several good ways. One is hold your finger in the spark plug hole, when you feel pressure, it's the compression stroke.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
04-10-2020, 03:55 PM | #7 |
Re: Help with TDC
04-10-2020, 04:02 PM | #8 |
Re: Help with TDC
These were the ones I used and found it to be very easy.
https://www.youtube.com/watch?v=5a2X9mSSlQY https://www.youtube.com/watch?v=FHX1yXVyIMg
04-10-2020, 06:56 PM | #9 |
All about them K’s
Re: Help with TDC
If it’s at tdc, someone probably just dropped the distributor in wherever it went in and corrected it with the firing order if that makes sense. I’ve seen it done this way when the oil pump shaft doesn’t line up and the distributor won’t go in with the rotor pointing to number 1. A long flat screw driver can be used to turn the oil pump shaft to line up the oil pump with the distributor.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-10-2020, 07:09 PM | #10 |
Re: Help with TDC
If the disty is engaged with cam gear you can’t lose timing and just turn crank with socket until oil pump shaft lines up and drops in
04-11-2020, 10:04 AM | #11 |
Re: Help with TDC
Thanks for all the help
What i got confused with is the dizzy moves once to every two turns of the harmonic balancer. I was under the assumption the dizzy moves by the ignition point on exhaust and then back around to compression. So i would get a compression stroke ( with thumb in spark plug hole) every full dizzy. Once I realized compression happened every full dizzy turn things got clear. Pretty embarrassing.... It's not a pretty sight out in my shop....still dealing with a walking boot after a full ruptured achillies tendon and surgery
04-11-2020, 10:08 AM | #12 |
Re: Help with TDC
It’s a 4 stroke.
04-11-2020, 10:12 AM | #13 |
Re: Help with TDC
Thanks Dan....was on the phone with your buddy Kevin yesterday getting updated on his truck
He shot me over a picture of his new man cave......It's nicer and bigger then my house!!
04-11-2020, 10:52 AM | #14 |
Re: Help with TDC
You know a Kevin. Started with a simple wiring clean up on his 68 and now has half the truck apart.
His building is awesome and overkill is evident everywhere
04-11-2020, 02:22 PM | #15 |
Re: Help with TDC
04-11-2020, 03:38 PM | #16 | |
Re: Help with TDC
Thanks for the well wishes
04-11-2020, 04:13 PM | #17 |
Re: Help with TDC
Here is a resource for all your engine needs:
https://www.crankshaftcoalition.com/...Coalition_Wiki Hope this helps, getting things better soon. |
