03-06-2021, 08:12 PM | #1 |
Rochester Quadrajet bolt hole size
Does anyone know the size of the bolt that will fit in these holes? I tried the bolts that I have and none of them fit.
03-06-2021, 08:41 PM | #2 |
Re: Rochester Quadrajet bolt hole size
What's the number on your carb?
The older carbs I think that was #10 x 32 threads? I can check tommorrow. If it a late model it has metric threads. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 03-06-2021 at 08:49 PM. |
03-06-2021, 09:14 PM | #3 |
Well I went out and grabbed the screw that goes in those holes and it's 12-28 UNF. They are c'sunk oval head screws. I even took a pic of the screw but I can't get it to upload.
Take Care Troy |
03-06-2021, 09:35 PM | #4 |
17080507
2801 DNR What is UNF? Don’t worry about the photos |
03-06-2021, 09:38 PM | #5 |
Thank you guys
03-06-2021, 11:18 PM | #6 |
17080507
170 means 1976 and later. 4th digit (8) means {in the 80's} 5th digit means (0) 1980 6th digit is Califorina only 7th digit is Chevrolet 8th digit is an odd number example (1,3,5,7,9) so it's a manuel trans. Link: https://www.chevyhardcore.com/tech-s...ication-guide/ (UNF stands for Unified Fine Thread) Link to threads : https://journeymans-workshop.uk/unified.php .
03-07-2021, 12:28 AM | #7 |
So does 1976 and later mean it is a late model? So does that mean it is metric?
03-07-2021, 12:34 AM | #8 |
I don't know for sure.
Your's looks like it would be standard screws. The ones that are metric have those torxs screws , But I would check the other screws with a thread pitch gage. Or with a standard screw just to be sure. .
