Old 03-27-2024, 09:56 PM   #1
rhc10
rhc10's Avatar
C7 brakes???
Will C7 ZO6 caliper and rotor work on my 68 C10?
Anyone making brackets kits to fit them? All I’ve seen is for C5/C6.
rhc10 is offline   Reply With Quote
Old 03-28-2024, 11:46 AM   #2
SCOTI
SCOTI's Avatar
Re: C7 brakes???
It could possibly be done as a hybrid assortment of parts just like they're done for various cars (& correctly spec'd wheels).
The main difference between the two is the multi piston 'fixed' caliper vs. the floating variety. But they used a fixed caliper on C6 Z06's so w/the right brackets either type of caliper can work.
I will ask.... Why fixated on C7 only?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-28-2024, 12:35 PM   #3
rhc10
rhc10's Avatar
Re: C7 brakes???
I just had an opportunity to pick up a set so was looking to see if it would work.
Old 03-28-2024, 12:58 PM   #4
PbFut
Re: C7 brakes???
Its a big caliper. It will likely run a fair price for all the other stuff needed. You need to figure out the spacing and required hat and rotor combo. Brackets can be made easy enough. Wheel fitment will be another issue to confirm. Easiest way to get things right is to find a king pin match to your truck. Make a stand and attach to your work bench and have at it. It's actually a fun project, but the deal on the take off calipers was probably the least of the expense. Custom Bracket, Hats, Rotor, adjustable proportioning valve and likely new wheels and tires. Your wallet will be a lot skinnier when complete.
PbFut is offline   Reply With Quote
Old 03-28-2024, 02:21 PM   #5
weq92f
Re: C7 brakes???
A long time ago I purchased a Baer Big Brake upgrade for a Trans Am. The kit was not too expensive and really worked well. Years later, I needed new rotors and the Baer price was CRAZY. With a little research and some effort I learned that the Baer kit was made up of OEM C-5 Corvette parts and so I got pads and rotors for reasonable money.
I would suggest that rather than sourcing and building your own kit from pieces, go and purchase a brake upgrade from one of the non-wilwood vendors...maybe even Baer. This will get you matched and tested component combinations that would likely perform just as well as the stuff you're looking at now.
Here's an example:
https://baer.com/1960-1987-C-10-C10-pickup-GMC-Brakes/
EDIT: Not dissing Wilwood at all, just figure the OP isn't into spending that much.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-28-2024, 03:41 PM   #6
SCOTI
SCOTI's Avatar
Re: C7 brakes???
Here's an example:
-Kevin
Those Baer kits are ~$2k. That's not exactly cheap.
I'm guessing rhc10 was trying for the budget approach & yielding the same basic parts @ half that cost.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-28-2024, 04:46 PM   #7
LS short box
Re: C7 brakes???
On my 68 C10 I bought the C5 kit from ? But he is or was on this forum. He supplied the modded stock height after market spindles, hubs, bearings and caliper brackets. I bought rebuilt C5 calipers and 13" C5 drilled and slotted rotors. SS flex brake lines.
I was running 20" wheels and I thought the 13" rotors look a little small so I made new caliper brackets that spaced the calipers out another 1/2" and bought 14" ZO6 rotors. The swept area of the 14" rotor and 13" is identical so the C5 brake pads worked fine. Got the caliper cores from Corvetteforums.com C5 parts for sale.
I have the 13" caliper brackets on the shelf. If you think you can use them they are yours for the shipping. I'm in central MN.
I've used the C5 brake stuff on a number of projects and they work well.
LS short box is online now   Reply With Quote
