12-28-2020, 06:06 PM | #526 |
Re: What did you do today not on your truck...
Since I'm retired now and spending a lot more time in the garage I installed a heater today. Had to run a new 220 line which went pretty quick. The instructions said one lag bolt in the middle of the bracket was good if you wanted to swivel the heater. Seemed a little to flimsy to me so I bolted it to the ceiling with three bolts. This is a 5000 watt heater that is suppose to be good for up to 500 sq ft. My garage is 20X25 so the math works out right on the money. It was 36 degree outside so I set it on medium and after an hour it was up to 58 degrees so that's where I set the thermostat. With a light jacket that's all I need.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
12-28-2020, 06:59 PM | #527 |
Technically this is not working on my truck.
Two weeks ago I brought home a new project. It's a 1980 Camaro Rally Sport. 28,000 original miles. Zero rust. Interior is almost perfect. I had to replace the head liner last week. No cracks in the dash. No splits in the seats. It's true time capsule. Bought from the son of the original owner. The dad bought it new in 1980 for $7400 out the door. The son gave me the original window sticker, invoice, sales brochure and I found the build sheet under the rear seat. Van Nuys build. The body is all original paint with a few nicks and scratches but I am not going to repaint. The bad it has the 229 V6 three speed on the floor. They were junk in 1980. Solution to the V6 is the 2012 6.2 LS on my engine stand. It will look like a barn find on the outside and modern underneath. See pics. |
12-28-2020, 07:53 PM | #528 |
Old member
Here at the beach. I got out this morning and installed a new GM mirror in the little red coupe and new gas pedal assembly. It's a much better system than what I had. It's all in the box. It is very smooth with no jerking at all now when I give it the gas.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-28-2020, 08:59 PM | #529 |
Technically I am supposed to be off work until January 4 but had to go to a Frito Lay plant today and try to get a new flow meter installed so they could get a line running. Factory sent the wrong transmitter so I didn’t get home until four in the afternoon and still did not get them going. Frustrating as now I gotta work even more on my time off to get the correct transmitter shipped and make another trip to install.
I was planning to finish my power disc brake conversion while I was off and have not touched it yet.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX Last edited by 67C10Step; 12-30-2020 at 10:47 AM. |
12-29-2020, 11:55 AM | #530 |
R.I.P. E.S.L.L.
I put the legs on my new sofa. What a disaster. What seemed like an easy job was anything but easy. When I would try to drill holes I'd hit something. I don't know what. But whatever it was it broke two drill bits. This thing was terribly designed and came with screws that were way too big. And of course I was out of shorter ones. So a trip to the hardware store and 4 hours later I finished it.
Now I have do the loveseat. Round 2 Here we go again.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
12-29-2020, 12:02 PM | #531 | |
12-29-2020, 05:39 PM | #532 |
Well, I got my Jeep back from the shop finally
Dang, that thing is sure small! But it's going to leave a lot more room in the garage. The 4runner is now going to have to sit out under a tree.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
12-30-2020, 04:54 AM | #533 | |
12-30-2020, 07:12 AM | #534 | |
71 C10 72 K20 72 K10 Super Kirk |
12-30-2020, 10:49 AM | #535 | |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
12-30-2020, 04:51 PM | #536 |
I was a line tech at a Chev dealer ship when this car was new. People thought the V6 would get better gas mileage than the 305 and it was just the opposite. Super restrictive cats, egr, air pump, retarded timing made these engines real dogs. I think GM just cut the front two cylinders off a 305 V8 so they never ran smooth. Front sheet metal is already off getting ready to pull the engine.
12-30-2020, 08:05 PM | #537 | |
Proprietor of Dale's Corner
Never mind, I found it. Thanks for starting it....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 12-30-2020 at 08:08 PM. Reason: found the answer to my question |
12-30-2020, 09:41 PM | #538 | |
Who Changed This?
12-30-2020, 09:52 PM | #539 |
So, not the same as the Buick V-6 that ended up in a lot of Jeeps ?
12-31-2020, 07:10 AM | #540 |
Buick made good V6s. Started out as the 3.2/198 in '62. It was a V6 engine designed to be a V6 engine and was a superior design. It got bumped up to 3.8/231 cu in (3800) and that's the design Kaiser bought in '67. GM bought it back about 10 years later during the energy crunch. By then AMC had bought Kaiser. The 3800 was actually derived from the aluminum 3.5/215 V8.
12-31-2020, 09:08 AM | #541 |
laying low
Weren't the 80's and up Chevy V6s a 60* engine or did those come later?
12-31-2020, 09:26 AM | #542 |
All about them K’s
The 2.8 was a 60 degree for sure, I had one in an ‘87 S10 blazer about 15+ years ago. I’d assume the later 3.0, 3.1, 3.4 are as well. That 2.8 4x4 S10 blazer was quite possibly the most gutless thing gm has ever built. 0-60 in 45 minutes. The 4.3 was the best thing that GM ever did for the S10.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-31-2020, 12:21 PM | #543 |
R.I.P. E.S.L.L.
Agreed.
We got a fleet of new S10's at work years ago. Only one of them was a 4x4 with a 4.3 and a/c. I was the supervisor and I assigned the trucks. Take a wild guess on which one I assigned to myself. Rank does have its privileges.
01-01-2021, 01:00 PM | #544 |
The Older Generation
I'm repairing a 2004 Chevy pickup instrument cluster this morning. Some of the backlights work but that is all. LockDoc
01-01-2021, 02:22 PM | #545 |
Those mechanics sure look a lot like electronics. Who says there's no future for TV repairmen?
01-01-2021, 03:59 PM | #546 |
Who Changed This?
Holy Smokes! That right there is why I bought the extended warrantee!
01-01-2021, 04:52 PM | #547 | |
All about them K’s
Yesterday we replaced an old circa 1955ish 145 Waukesha on a produced water injection well at work. It committed suicide by dropped valve earlier in the week. The last of a dying breed we’ve got. There’s enough guys around here with interest in old equipment and engines I thought some may find it interesting. We replaced it with a CAT turbo 3306 natural gas.
01-01-2021, 05:27 PM | #548 |
Was that old govt surplus?.
01-01-2021, 05:29 PM | #549 | |
01-02-2021, 12:23 AM | #550 | |||
I was able to get this one repaired by re-soldering all of the resistors (29 of them) and replacing a few bulbs. LockDoc
