01-17-2010, 02:50 AM | #176 |
Re: Truck Options Survey
1. 1971
2. Chevrolet 3. Base C10 4. Longbed 5. Fleetside 6. Bench 7. Black 8. Oh! Green (lime) with white roof 9. Lower trim only, black 10. 350 11. TH350 12. Original Power Steering 13. Manual discs 14. No Air Conditioning 15. 2 Wheel Drive 16. 3.07
"You can take the man out of PA, but you can't take PA out of the man" |
01-17-2010, 01:48 PM | #177 |
Born Psycho
1- 1972
2- chevrolet 3-cheyenne super/10 4- longbed 5-fleetside 6- white/black houndstooth original, now black buddy buckets 7- parchment/black 8- dark olive/white 9- upper/lower w/woodgrain 10-350 11- 350 12- power steering 13- power brakes 14- air conditionong 15- 4 wheel drive 16- 3:07 factory now 3:73 options i've added- tilt, tach, vacuum, am/fm, shoulder belts,buddy buckets,posi front and rear, tow hooks,speedwarning, toolbox/aux.fuel tank, bumper guards, sport rear bumper, 3/4 ton axles. goodies to be added some day-i hope- oem cargo tie downs, door edge guards,rear tow hooks and 16.5 x 8.25 steel wheels with stainless dog dish caps. i also have a 72 cheyenne/20 4x4 with the same list of goodies except it's a 4 speed instead of auto trans and it's original all white with all black interior. my uncle bought it brand new
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
09-11-2010, 12:38 AM | #178 |
1. 1968 2. chevy 3. c10 4. Shortbed 5. Fleet 6. BMW 3 series bucketseats, LMC repro center consul 7. Interior Color = black 8. Exterior Color = Metallic Burgundy Pearl 9. Stock wheel/side trim (mar-K) 10. Built 305 (.40 over) roller performance w/roller rockers, ported/polished heads, Keith Black pistons, GM HiPo cam 11. 4 speed 700R4 w/shift kit 12. Power Steering 13. Power Brakes w/7" booster/dual master cylinder 14. Vintage "Sure-Fit" Air Conditioning 15. 2 Wheel drive 16. posi, stock 3.73 ratio Chrome 16" American Racing IROC rims, all gauges,speed,fuel,oil, temp, charge,vacuum and tach with white faces. Tom
Bamafrost "Wars fought, uprisings quelled, Coup d'Etats planned...right after my nap". '68 Rambler American 2 door post Built 340/727/8.75 w 3.73 posi '68 C10 shortie soon to have a 2.5/4 drop and new Americans: 16" x 8" chrome IROC's |
09-11-2010, 12:53 AM | #179 |
my 67
before 1. 1967 2. chevrolet 3. C/20 4. longbed 5. fleetside 6. bench 7. int. blue 8. ext. white 9. no tirm at all 10. 327 sbc 11. 350 turbo hydramatic 12. no power steering 13. no power brakes 14. heater cab 15. 2wd 16. 4.11 gears now 1.1967 2.chevrolet 3.CST/10 4.short 5.fleet 6.buddy buckets customcab dooor panels pass. sun visor tilt colum 7.int. gloss black 8.ext. semi gloss black with gloss white top 9.ext trim.67 trim lower as well as tailgate and below window 10. 302 from 1969 Z/28 camaro 11. 350 auto 12.power steering 13. power brakes 14. not yet 15.2wd 16. 3.73 Last edited by 67chevy1series; 06-20-2011 at 06:18 PM. Reason: added better info about my 67 |
09-11-2010, 01:09 AM | #180 |
1. Year: 1968
2. Make: C10 3. Package: Base model 4. Longbed 5. Fleetside 6. Interior: Bench seat 7. Factory interior color: Gold 8. Factory Exterior Color: Gold 9. Factory Exterior Trim: none 10. Factory Engine Size: inline six, not sure if 250 or 292 PO swapped motors has a 350 now. 11. Factory Transmission: Muncie #spd on the column 12. Manual Steering 13. Manual Brakes 14. Heater, not there anymore, PO removed it 15. 2 Wheel Drive 16. Axle Ratio: 3.73
'68 C10 LWB 6.2NA/NP833 3.73's |
09-11-2010, 07:39 AM | #181 |
1. 1969
2. Chevy 3. Base C10 4. Longbed 5. Fleetside 6. Bench 7. Who knows? Probably dark green. 8. Dark Green 9. None 10. 292 11. Saginaw 3 speed 12. Nope 13. Nope 14. Nope 15. 2 Wheel Drive 16. 3.73, no posi 1968CHEVYC10, your truck sounds a lot like mine, based on these questions.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 Last edited by cam.man67; 09-11-2010 at 07:40 AM. |
09-11-2010, 10:03 AM | #182 |
1. 1969
2. Chevrolet 3. C10 Custom 4. Shortbed 5. Fleet 6. Bench 7. unknown 8. unknown 9. None 10. 350CI 11. 4 speed now 700R4 12. Power Steering-Stock 13. Power Brakes-Added 14. Air Conditioning-Stock 15. 4 Wheel Drive 16. 3.73
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
11-09-2010, 08:56 AM | #183 |
1. Year: 1970
2. Make: GMC C/1500 3. Package...Cheyenne, Sierra, etc: Custom Sport Truck 4. Short or Longbed: Short 5. Fleet or Stepside: Fleetside 6. Interior...Custom, with bench, buckets, etc: bench 7. Factory Interior Color: Black 8. Factory Exterior Color: black 9. Factory Exterior Trim...Upper & Lower, Black or Woodgrain: Woodgrain 10. Factory Engine Size: V8 400cu 11. Factory Transmission: 400 12. Power Steering, State if you added it. Factory Power steering 13. Power Brakes, State if you added it. Factory Power brakes 14. Air Conditioning, State if you added it.: Factory A/C 15. 2 Wheel or 4 Wheel Drive: 2wd 16. Axle Ratio: positrac All factory
1970 GMC C1500 402 SWB Last edited by 70gmccst; 11-09-2010 at 02:01 PM. Reason: axle and engine size |
11-09-2010, 10:12 AM | #184 |
1. Year--------1971
2. Make --chevy 3. Package...Cheyenne, Sierra, etc---- custom 4. Short or Longbed---long 5. Fleet or Stepside------fleet 6. Interior...Custom, with bench, buckets, etc ---bench 7. Factory Interior Color----n/a 8. Factory Exterior Color--------n/a 9. Factory Exterior Trim...Upper & Lower, Black or Woodgrain--none 10. Factory Engine Size--350 11. Factory Transmission--th350 12. Power Steering, State if you added it.---yes stock 13. Power Brakes, State if you added it.---no manual 14. Air Conditioning, State if you added it.-- yes stock 15. 2 Wheel or 4 Wheel Drive--2wd 16. Axle Ratio 4.10 |
11-09-2010, 12:31 PM | #185 |
1. 1970
2. Chevy 3. C10 4. Longbed 5. Fleet 6. Interior...bench 7. Factory Interior Color - Blue 8. Factory Exterior Color - 2 tone white/med. blue 9. Factory Exterior Trim...Lower, Black 10. Factory Engine Size - 307 11. Factory Transmission - 3 sp manual 12. Power Steering - No added it. 13. Power Brakes - No 14. Air Conditioning - No 15. 2 Wheel 16. Axle Ratio - 3.73
1970 Chevy C10 LWB 307 3OTT 3.73 gear |
11-09-2010, 07:20 PM | #186 |
1. Year: 1967
2. Make: C10 3. Package: Base model 4. Shortbed 5. Stepside 6. Interior: Bench seat 7. Factory interior color: silver 8. Factory Exterior Color: Silver Poly 9. Factory Exterior Trim: none 10. Factory Engine Size: inline six, not sure if 250 or 292, now a late 1970's 350 11. Factory Transmission: M20 4 Speed, now a TH350 12. Manual Steering, now power steering from a 71/72 13. Manual Brakes, suspension and brakes from a 71/72 14. Heater 15. 2 Wheel Drive 16. Axle Ratio: I have no idea what the original ratio was but it currently drives like 3.07's. It had been updated with the driveline out of a 71 / 72 C10
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
11-14-2010, 12:21 AM | #187 |
1- 1972
2- Chevrolet 3- Cheyenne 4- shortbed 5- stepside 6- custom bench 7- black 8- silver [special paint 4001 CA] 9- none 10- I6- [size unknown] 11- 4 speed 12- yes 13- added ? [was there when I got it, not on SPID] 14- no 15- 2WD C-10 16- factory gear unknown This is the only Cheyenne stepside I have seen and until I saw Petey-Pablos post the only Cheyenne I6 I knew of. Anyone know of others? SPID reads as follows- model # cs10704 A11 Tinted Glass M20 4spd trans N40 Power Steering U63 AM p/button radio VF1 Chrome Rear Bumper YF5 Cal Vehicle Reg. Z53 Amp-Oil-Temp Gauges Z84 Cheyenne Equip. 603 Black Vinyl Custom Trim 4001CA Special Paint Truck now is 350/350, lowered on 15" Slot Mags, tilt, tach, Buddy Buckets, power windows, '65 Vette steering wheel, and 3.07 rear gear. This is a good thread if you have not yet filled out the info please take the time, it is interesting to see what came with or without what. |
11-14-2010, 01:03 AM | #188 |
Ex-Minitrucker
1. 1968
2. Chevy 3. Custom 4. Longbed 5. Fleetside 6. Factory with bench 7. Dark Green 8. Dark Green 9. None 10. 292 L6 11. Granny 4spd 12. No Power Steering 13. Four Wheel Drums 14. No Air Conditioning 15. 2 Wheel Drive 16. Factory Unknown Axle Ratio
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd |
11-14-2010, 01:04 AM | #189 |
1. 1972
2. Chevrolet 3. Custom 20 4. Longbed 5. Fleet 6. Bench 7. Dark Green cab white door panels Black Dash pad and Steering wheel 8. White and Dark Olive 9. Upper & Lower, Black 10. 350 11. 350 12. Power Steering 13. Power Disc Brakes 14. Air Conditioning 15. 2 Wheel 16. Factory Dana 60 Not sure of ratio
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. Last edited by JCD; 11-14-2010 at 01:09 AM. |
06-20-2011, 05:15 PM | #190 |
ttt for a good thread
06-20-2011, 06:03 PM | #191 |
1. 1970
2. Chevy 3. C-10 4. Longbed 5. Fleetside 6. Custom cloth 7. Blue 8. Blue - white roof 9. Upper trim only 10. 350 11. 350 12. Power Steering - Factory 13. Power Brakes - added 14. Air Conditioning - Factory 15. 2 Wheel Drive 16. 3:90 ? - added 3:42-positraction A few more have been added !!!
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
06-20-2011, 06:11 PM | #192 | ||
"I ain't nobody, dork."
1. Year: 1972
2. Make: GMC 3. Package: 1500 Super Custom 4. Longbed 5. Fleet 6. Interior: Stock bench seat with rubber floor mat 7. Factory Interior Color : Black 8. Factory Exterior Color: Green w/white top (white is now black) 9. Factory Exterior Trim: Lower, Black 10. Factory Engine Size: 350 11. Factory Transmission: TH350 12. Power Steering: From the factory 13. Power Brakes: From the factory (Factory front discs as well) 14. Air Conditioning: None 15. 2 Wheel Drive 16. Axle Ratio: Stock 3.08, open diff (now has 3.73's and a posi) Pretty cool thread. Gary
06-20-2011, 06:13 PM | #193 |
"brand new second-hand"
Year 1969
2. Make Chevy 3. Package...Custom Camper/20 4. Longbed 5. Fleet 6. Interior...factory with bench-added buddy buckets,tilt,cruise,speedminder/tach/air pressure,am/fm 7. Factory Interior Color-dark blue 8. Factory Exterior Color-dark blue/white top 9. Factory Exterior Trim...Upper & Lower, Black 10. Factory Engine Size 350.......changed to 454BB-added aux.battery 11. Factory Transmission th400 12. Power Steering, Factory 13. Power Brakes, Factory 14. Air Conditioning, Factory 15. 2 Wheel Drive 16. Axle Ratio 4:11 factory- rearend changed to 1986 w/3:23 All additions were made with factory parts
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
06-20-2011, 06:23 PM | #194 |
might as well do my dads.
1970 2 chevrolet 3 custom/10 4 longbed 5 stepside 6 bench, am radio, non tilt 7 white w/red 8 white 9 lower trim (black not woodgrain) and trim below the window 10 350 sbc 11 350 auto 12 power steering 13 power brakes 14 A/C cab 15 4 Wheel Drive 16 3:73 gears front and back |
02-19-2012, 12:02 PM | #195 |
ttt!!!!
02-20-2012, 12:38 AM | #196 |
1. 1972
2. GMC 3. Sierra Grande 4. Longbed 5. Fleet 6. Custom Cloth Bench 7. Blue 8. Dark Blue/Med. Blue 9. Upper & Lower Woodgrain 10. 350 11. TH350 12. Factory P.S. 13. Factory P.B. 14. Factory A/C 15. 4WD 16. 4:10
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
02-20-2012, 01:12 AM | #197 |
1. 1969
2. Chevy 3. Custom 4. Longbed 5. Fleetside 6. Custom color bench 7. Olive Green 8. Med. Green and white Combo 9. Upper and Lower Black 10. 350 11. th400 12. Factory PS 13. NONE 14. NONE 15. 2WD 16. 3:73 posi
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
02-20-2012, 03:45 AM | #198 |
Lemme show you something!!
1. 1967
2. GMC 3. Custom 4. Shortbed 5. Fleetside 6. Black Vinyl Bench 7. Fawn Interior 8. Med.Green Exterior 9. No Trim 10. 283 cu.in. 11. SM420 4-speed 12. Power Steering 13. Manual Brakes 14. No A/C 15. 2wd 16. 3.73
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
03-26-2012, 12:16 AM | #199 |
ttt
04-22-2018, 11:27 PM | #200 |
1. 1967
2. Chevy. 3. Base (cheapest) 4. Looong 5. Suburban 6. 2 benches ( long center) 7. Light green 8. 503 green 9. None installed when I I bought. SPID says "Side trim mould eq" 10. 327 11. SPID says Turbo Hydromatic. Has T400 installed. 12. Manual has Power now 13. Has power brakes but not mentioned on the SPID. 14. Nope 15. 2wd non posi. 16. PO says he pulled 3:73's and put 3:50's with a posi. Great thread! One more gem recently unearthed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
