Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-15-2021, 03:49 PM   #1
MAC71Cheyenne
Heater control head lighting, works..then not.
This one has me stumped. The bulb n socket on the right side work fine when it is out of the head and grounded by just touching the bottom lip of the dash or the back of the head. Once the bulb/socket is fully inserted it goes out. Socket tabs are making contact with the case its not loose, and bulb is fully seated. As soon as you loosen the socket and back it out a smidge it lights up. No strain on the socket wire...
The wire and socket for the left side blower speed is m.I.a at this point but moving from right to left it lights up but is dim. There is no other wires touching the controls with the exception of the blower switch wiring.
Sounds like a bad ground or short but test light grounded to the head lights up like it should and is not dim.
MAC71Cheyenne is offline   Reply With Quote
Old 01-15-2021, 11:28 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heater control head lighting, works..then not.
Did you check to make sure the bulb is correct for the socket and it's not got a loose filment.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-16-2021, 12:53 AM   #3
MAC71Cheyenne
I did...New 168's. Socket contacts are good. Bulb is tight with no wiggles. Makes no sense, Upon contact with the back of the housing it lights up as it should, works perfect until seated in the back of the case. There is no obstruction between the bulb head and back side of the display. Screwy!
Old 01-16-2021, 12:49 PM   #4
dmjlambert
dmjlambert's Avatar
I had a license plate light that did that same thing. I took the socket off the truck, cleaned it up really well, cleaned up the hole in the bumper, tested it off the truck and it worked fine. No matter what I did, it did not work when inserted all the way onto the truck. In my case the only thing to do was replace the socket assembly, and then it worked fine. I am pretty confident at fixing electric stuff, but that bulb assembly was mysterious.
Old 01-16-2021, 02:39 PM   #5
Andy4639
Old member
Andy4639's Avatar
Take a jumper wire and place it into the fitting of the socket. The clips that hold it in place and touch it to a good spot to ground it and see what happens.
Old 01-16-2021, 07:38 PM   #6
MAC71Cheyenne
Spark! Test prob worked too...can't get up there to see but next step is to clean up the mountain hole inside edge with some emery cloth. Got to finish installing my dash pad first, got sidetracked with this mess. Clean, power, ground...shouldn't be that hard right Andy?
Old 01-16-2021, 09:12 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heater control head lighting, works..then not.
Yea, if you say so sir!
Electrical work can be the most frustrating work there is sometimes
