Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-30-2020, 07:32 PM   #1
skip99
skip99's Avatar
Electric fan fuse or breaker
Installing elect. Fan...should i use a 40a fuse or a circuit breaker? Why?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 12-31-2020, 10:41 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Electric fan fuse or breaker
If you use a fuse and it blows you will have to change it. If you use a circuit breaker once it cools off it will reset on it's own.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-01-2021, 01:50 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I'm afraid that if you blow a 40 amp fuse or a circuit breaker you have got bigger problems. I think a breaker might work better like Andy said if it was a one time deal, but that much draw would probably mean a seized fan motor or a dead short in the power feed wire to the motor. Here 's a couple of diagrams with a 30 amp fuse. One has a manual override switch and the other with a light also wired in to show the fan is running.
Name:  fan on manualpontiac_cooling_system+diagram2.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-01-2021, 05:34 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Electric fan fuse or breaker
VetteVet,
Just buy the switch that has the light built into it.
Old 01-01-2021, 07:35 PM   #5
skip99
skip99's Avatar
Attachment 2071116
Attachment 2071115
Thats my point, everyone says a breaker is better because it will reset, but if the motor seized, wouldnt a fuse be better?
I know how to wire one, im actually using dakota digital controller, just not sure if to use fuse or breaker
Tami's 51 build
Old 01-02-2021, 01:24 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by Andy4639 View Post
VetteVet,
Good point Andy, but the light in the switch would only show the fan running in manual override, when the switch was on. I think whoever made the drawing wanted to show the fan on anytime it was running.
I don't know if I'd want a light coming on and going off every time the fan cycled.
VetteVet
Old 01-03-2021, 08:28 PM   #7
Andy4639
Old member
Andy4639's Avatar
The circuit breaker would just trip out and never reset I don't think in the case of the motor seized up.
Old 01-03-2021, 08:36 PM   #8
Andy4639
Old member
Andy4639's Avatar
Hard to tell by the drawing... but it's tied into 12 v in to the light and then 12 volts out to the over ride. So if the switch isn't turned on the light want be on will it? It looks like he wants it to tell him the over ride is on so he knows when to cut it off. Not very clear on that wiring schematic though.
Old 01-05-2021, 01:10 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I agree with you that the drawing is not very clear. I shouldn't have posted it without explaining how the light worked. I keep forgetting that not everyone understands how wiring circuits work.
This is one of those times when the switching is done on the negative side of the circuit, Similar to the windshield wiper motor and the courtesy light in the cab.
In this case it's the relay for the fan, via the temperature sensor, and the over ride switch.
The OR switch doesn't need any positive voltage to trigger the fan relay. It does exactly what the temperature sensor does, only it does it manually. Why he shows the red positive wire to the switch is proof that the drawing is flawed. The red wire should go straight to the light to provide it with positive current, or it should go to 2 separate terminals on the switch.(single throw double pole)If he meant to show it with just the OR switch on, like you said. If you look closely at the the switch you can see that there is no terminal for the red wire there and it appears to be connected together.
The ground for the light is provided by the black wire from the relay which
is switched on by the temperature sensor or the OR switch. So the light will illuminate any time either one of those grounds the fan relay.
VetteVet
