Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-04-2021, 03:12 PM   #1
skip99
skip99's Avatar
Make a park light blink?
Any ideas on how to make a park light blink with blinkers? Heres the kicker...i want the park lights to be on and then blink with blinkers ........im wanting to use the halo in headlights as park lights, but then blink when switched...
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 01-04-2021, 03:24 PM   #2
skip99
skip99's Avatar
Re: Make a park light blink?
I think i have it, how about running park light pos. Through nc side of a relay, to the leds, then using blinker hot to remove the power through relay to light? Sound right?
Tami's 51 build
Old 01-04-2021, 09:56 PM   #3
Richard
Should be able to ground the park light to the +12v on turn signal. That is how it is done on the 71-72's factory side markers. Park light will alternate with turn signal. Led's may complicate it. Does not hurt to try.
Richard
Old 01-08-2021, 08:27 AM   #4
skip99
skip99's Avatar
Leds would def be different, cant use them as a pathway....have to use diodes , and maybe an electronic flasher, any other ideas? I can figure it out but would be nice if a “box” was already available..lol
Tami's 51 build
Old 01-09-2021, 01:20 PM   #5
Andy4639
Old member
Andy4639's Avatar
I'm not sure of what you want are if it's possible. The parking lights are separate system from your turn signals.
Parking lights come on by the head light switch. They are only on if the head light switch is used.
The turn signals are on all the time because they run through the steering column turn signal switch. If you only have one wire to the LED's the the rear tails will flash also when you hook the fronts up.
I have a set of head lights with the parking LED's & turn signal's in it and they have their own separate wires. I never hooked the blinkers up just the parking lamps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-15-2021, 02:47 AM   #6
67 Burb
67 Burb's Avatar
Re: How to make a park light blink.
On my 51 Pontiac project, the front park lights are single contact sockets so I though I would use them as daytime running lights. But then I had to come up with a way to have front turn signals.
I found that my electronic flashers will flash a relay, so I bought some bright amber LED bulbs with the 1156 base and drew up a circuit to flash them.
You will need two relays, one for each side. The only weird thing is that the front signal / park lights will flash off when the rear signal flashes on. (But who sees the front and back at the same time?) Here it is:
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 01-16-2021, 12:49 AM   #7
franken
As Andy mentioned park/tail and turn/brake lights aren't the same. The brake and turn signals are the bright filament so they show even if the park/tail lights are on.
franken is offline   Reply With Quote
Old 01-16-2021, 06:53 PM   #8
skip99
skip99's Avatar
Looks like this willwork..
Tami's 51 build
Old 01-17-2021, 03:01 AM   #9
67 Burb
67 Burb's Avatar
That should do the trick. The reason I went with the relays, is that I wanted to have the park lights on bright rather than ~half power.
I tried the same method as you came up with when I built the LED tail lights for my Suburban using the LED arrays from a couple of Hyundai SUV's hi-level brake lights. I just couldn't get it to work the way I wanted.
Bob
Old 01-17-2021, 08:10 AM   #10
mongocanfly
Post Whore
mongocanfly's Avatar
ive modded park lights into blinkers before by changing the bulb sockets from 1156 to 1157...
not sure if this helps or not
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Thread Tools
Display Modes
