07-24-2018, 12:31 AM | #1 |
12-14 degrees of slop.
Sighhhhh.......hand pulling the motor around to get to TDC......look up.....rotor is pointing at between cylinder 2-4. On top of that....the timing marks travels the distance of the timing tab before the rotor starts to move...ugh. Before I go putting a new timing set in this, I suppose I should do a full compression check and see where the motors at. Did GM run nylon coated gears in these like Mopar did? It's got great oil pressure.....but if the compression is too low.....no point in going any further for now.
Patch |
07-24-2018, 06:46 AM | #2 |
Re: 12-14 degrees of slop.
Cam timing that retarded is likely going to effect compression. Leakdown would be a better test for piston/ring sealing.
I don't know what year GM started using plastic on the cam gear but they did use them
07-24-2018, 09:32 AM | #3 |
If the timing is off the compression numbers won't be correct. In order to develop compression the valves have to open and close at the appropriate times.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-24-2018, 09:49 AM | #4 |
Proprietor of Dale's Corner
My 89 V3500 with a 454 had the nylon cam gear. It let go at 190,000 miles.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-24-2018, 09:54 AM | #5 |
My original 75,350 had the plastic (coated) cam timing gear.
So,they did it that far back. Mike. |
07-24-2018, 12:10 PM | #6 |
So with a leak down vs. a compression check, I'll get it to TDC and pressurize that cylinder and see how long it holds pressure? Never done it that way but I understand the method. I hadn't even thought of the compression not being true during the test if the chain had jumped and it was out of phase. Thanks a bunch......
Patch |
07-24-2018, 01:44 PM | #7 |
Get the numbers off the block, Yes GM did use those plastic coated gear sets. But not in the original motors. Even if you have an original motor it does not guarantee you do not have metal gear sets, someone could have rebuild it with that crap.
I did a top end rebuild on my original motor with a dual roller set 75k miles ago, I have 2 degrees of slop in the timing chain now. That should give you something to gauge what you have going on without tearing the motor apart. Lots of people neglected these vehicles for years and did not realize how much of a working machine they are. |
07-24-2018, 02:17 PM | #8 | |
Patch |
07-24-2018, 08:32 PM | #9 |
if the timing is so far off that you cant do a compression test a leakdown test wont work for the same reason . it will tell you your valves are open or push the piston down . going to have to replace the chain and gears first unfortunatly
07-24-2018, 10:18 PM | #10 |
QUOTE=firedemon;8308105]if the timing is so far off that you cant do a compression test a leakdown test wont work for the same reason . it will tell you your valves are open or push the piston down . going to have to replace the chain and gears first unfortunatly[/QUOTE]
Yep.....that's what I'm going to do.
Patch |
07-25-2018, 12:43 AM | #11 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
