12-17-2017, 08:10 PM | #1 |
new coil springs
1970 C10
350cu/350 auto short bed converted fully restored this past year and mostly stock so my spid states that my truck has heavy duty springs. The ride is decent but I was considering changing the springs to a standard or non heavy duty if that makes sense. with 3 other trucks i used for work I have no need to load or haul with this c10. any suggestions on whether this will make a difference? I'm guessing heavy duty springs were and option and not standard? any brand you could suggestion any input appreciated. thanks! RRM
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
12-17-2017, 11:48 PM | #2 |
Junior Member
Re: new coil springs
When I rebuilt the front end on my 72 last year I went with Moog HD. With the 1 1/4 inch sway bar I added it is pretty stiff. If I ever have to do the ball joints again I'll probably switch to standard springs. Handles the curves well, but on rough surfaces it's too harsh to be comfortable.
12-18-2017, 12:11 AM | #3 |
the "heavy duty" springs on your 1/2 may be nothing more than a set for the big block or even a 3/4 ton. I would just order a set for a 1/2 ton small block
12-18-2017, 12:43 AM | #4 |
Wouldnt this be referring to the REAR springs as thats where the additional payload rides?
12-18-2017, 04:42 PM | #5 |
12-18-2017, 08:34 PM | #6 |
So checked the spid again this morning and yes it's HD rear springs. I assumed it was front and back.
Going to get standard spring and possibly 1.5" lowering blocks to level stance. Thanks for input. Such a great board here RRM
