09-16-2020, 09:29 PM | #1 |
2005 Sierra 2wd LH side lean correction & lowering
My Sierra has the much discussed LH lean that I want to correct. I also want to lower the truck. What would happen if I just put new drop coils in? Would this correct the lean or just lower the lean?
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
09-16-2020, 10:35 PM | #2 |
67-72 parts collector,…
Re: 2005 Sierra 2wd LH side lean correction & lowering
The lean will still be there.
I either trim the “high side” or add a Belltech spring spacer under the “low side” front spring.
09-16-2020, 11:11 PM | #3 |
Thanks Keith....I thought a bit about trimming the higher side. What would be a reasonable amount to cut off? Half coil at a time? Is the reason it would still lean because of the rear spring pulling it down?
09-17-2020, 12:47 AM | #4 |
I’m not sure what causes the lean. Fuel tank on one side? I don’t known
Be conservative on your cutting and sneak up on it. 1/2 COIL = 1” of drop.
09-17-2020, 07:20 AM | #5 |
Since I had a small floor jack, some chains and tools in my truck under the tonneau cover I made a little box to hold it on to the passenger side of the bed near tailgate and it leveled my truck out.
I have heard so many stories why there is lean like the gas tank & driver weight. I do know on my 02, the spacers they added from factory for quietness and the lean, deteriorated and made the lean worse. A friend of mine swapped his leaf springs around when he lowered his and it seemed to help get rid of it. Personally, I think the leafs are more of the issue that the front coils, but the front coils are easier for most folks to tinker with..
09-17-2020, 07:23 AM | #6 |
Pretty sure its the tank. My thought was that maybe since the springs on that side have both sagged a bit that if something was done first, the softer rear spring was the cause of it still leaning. I agree with the conservative approach...made that mistake years ago on a '83 Cutlass...thought I knew what was what & could not have been more incorrect :eyeroll:...thank goodness for the internet!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 09-17-2020 at 07:54 AM. |
09-17-2020, 09:42 PM | #7 | |
09-18-2020, 06:03 AM | #8 |
I think they (at least mine were) on the top of the spring. They may have both, but the drivers side top is what deteriorated on my 02.
09-18-2020, 08:14 AM | #9 |
Moderator
A good spring shop can re-arch leaf springs.
Swapping LH & RH springs is fairly easy as well.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
10-03-2020, 11:56 AM | #10 |
I think I'll give the springs a swap and see what happens....I did get a new spring insulator off of ebay the other day...thanks for the insights & I'll make sure to keep you updated
