02-25-2018, 01:53 AM | #1 |
Holley 3310-10
I bought a used 3310 and currently rebuilding it, But i can not figure out where the balls in the rebuild kit go?
Also on the manual choke is there a spring that goes in the fast idle cam plate? It looks like something goes in it, but mine doesn't have anything. |
02-25-2018, 10:51 AM | #2 |
Re: Holley 3310-10
IIRC the check balls are for the accelerator pumps.
Look in here for your carb. There should be a pic to help with that. http://www.carburetor-parts.com/Free...ls_ep_274.html On the manual choke there’s a spring with a tiny button that goes in the hole. Most people who ran them took it apart and threw the button and spring away. The button usually got gummed up and the choke was hard to move. It’ll run fine without it. |
02-25-2018, 07:15 PM | #3 |
Re: Holley 3310-10
There's a check ball between the secondary diaphragm housing and the main body, DO NOT leave that one out!
02-25-2018, 10:59 PM | #4 | |
Re: Holley 3310-10
02-26-2018, 01:09 AM | #5 |
Re: Holley 3310-10
