11-16-2020, 08:32 PM | #1 |
Shaving intake manifold
I have a gen4 5.3 in my truck that comes with the tbss intake on it. I’ve decided that I don’t want to have the engine cover on the truck anymore, but the factory manifold just doesn’t look good. So I picked up another manifold at the pick and pull yesterday for $32. I started the shave on it. I’ll post pics of my progress as I go along. I’m gonna move the pcv to the rear of the intake, but I believe I’m gonna leave the map sensor where it is.
11-16-2020, 09:33 PM | #2 |
Re: Shaving intake manifold
Nice clean look when you get it done, have you seen what (1971 step side build) did with his.
11-16-2020, 09:37 PM | #3 |
11-16-2020, 09:53 PM | #4 |
I did one a few years back, ended up not really liking it after the fact and didn't use it.
11-17-2020, 07:47 AM | #5 |
Hope he doesn't mind sharing, his work. I have seen this on Video somewhere, cool process. I have no idea how it works. ....http://67-72chevytrucks.com/vboard/s...d.php?t=768975
11-17-2020, 09:04 AM | #6 |
Paint it to match your body color, or add your own design.....limitless possiblites...I did some valve covers, takes some time masking for fine details.
11-17-2020, 01:18 PM | #7 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-17-2020, 10:02 PM | #8 |
11-21-2020, 09:33 PM | #9 |
My first attempt. Haven't ran it yet but looks better than stock IMO
11-21-2020, 09:53 PM | #10 |
I wanted to do one in the GMC Plaid
11-22-2020, 11:04 PM | #11 |
I worked a little on it yesterday. Not much progress though
11-23-2020, 12:42 PM | #12 |
Had mine done a couple of years ago, turned out pretty good.
12-06-2020, 11:50 AM | #13 |
Following
12-07-2020, 11:50 PM | #14 |
So progress is slow. This weekend of the weather cooperates I’ll prime and paint it. Even without paint I think it looks much better.
12-08-2020, 03:00 PM | #15 |
smoothed truck intakes look really really good! When I was going to LS swap mine that is exactly what I wanted to do.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
12-09-2020, 12:30 AM | #16 |
I’ve only seen a couple of shaved tbss manifolds. I’m looking forward to getting this complete.
12-09-2020, 01:35 AM | #17 |
6>8 Plugless........
I did mine on my Camaro and I think it looks pretty slick.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-19-2020, 12:12 PM | #18 |
What intake is this? External it looks like a regular 99-06 intake, but has a flange for a 4 bolt throttle body. It's on a 07 Trailblazer. But it's not the bread box.?!
12-19-2020, 01:38 PM | #19 |
It’s the gen iv truck intake I think. But since it’s on a trailblazer it maybe a little different then the trucks. I think in the trailblazer SS they used the ls2 motor with a truck intake for the torque. A lot of knowledge here so I am sure someone will correct me if I am incorrect.
The truck intakes are ugly but are better for trucks due to the torque values then the car intakes. But depends on application.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
09-08-2021, 07:01 PM | #20 |
It’s been a while since I worked on this last, but I’m about finished with the intake shave.
09-15-2021, 01:26 PM | #21 |
Looks good. I usually dont care for the look but that came out really nice.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
09-20-2021, 11:34 AM | #22 |
What was your method of shaving it down?
09-20-2021, 09:03 PM | #23 |
