08-20-2019, 08:25 PM | #26 |
Re: DIY seat cover
I just bought a set of bucket seats and the passenger side foam is great but the driver side bottom in rough shape. Can it be repaired or just get new foam bottom?
08-21-2019, 03:33 PM | #27 |
landarts
Re: DIY seat cover
I have done this both ways. I replaced buddy bucket seat foam top and bottom, makes them like brand new. Also makes you sit higher and stiff. I have repaired several bench seats drivers side foam. I used a electric knife like you cut the turkey with. Cut out shapes that are easy to replicated with the replacement foam, like squares and rectangles. Used a spray adhesive to attach new foam, then carve to fit contour. The trick is getting foam that is the right density.
71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 69 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
08-21-2019, 08:16 PM | #28 |
Re: DIY seat cover
Where can you find the correct foam and what density foam ddi you use?
08-21-2019, 08:30 PM | #29 |
Re: DIY seat cover
American Cushion Industries sells the Best foam,
http://www.americancushionind.net If you are in Northern California I can do your seats for you.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
