Old 03-17-2019, 11:49 AM   #1
bmxbang
Quick wheel question
Alright guys just want to make 136% sure that I have this right. I have a 71 2wd. I just sold the aftermarket wheels off it that came on the truck when I bought it. Im looking to just get some steel wheels for now to get me by until I decide to drop a dump truck worth of cash on the final wheels.
Chevy & GMC 1/2 Ton Trucks (2WD) '88-'98
Will I run into any problems with getting some steel wheels off these guys? Is the Backspace and offset good so they will look like the belong on there? Fitting and then fitting correctly are two different things.
The truck does run and drive and is capable of doing Highway speeds. Just want to make sure I won't run into any problems. Everything I have read online and on here looks to be that I won't have any I just wanted to be 136% sure.
Picture just because who doesn't like seeing pictures
bmxbang is offline   Reply With Quote
Old 03-17-2019, 12:31 PM   #2
GMCPaul
Re: Quick wheel question
Unless I'm remembering this incorrectly as it may only possibly apply to the 88-98 6 lug wheels but I'm rather sure it's the same with the 5 lug wheels. The 88-98 hubs are smaller than the 67-72 so the center opening on rims will be to small a diameter to fit over your current hubs.
Paul Sr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 03-17-2019, 01:41 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Paul Sr @ GMCPauls
X2 they won't fit.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-17-2019, 05:55 PM   #4
rockyrivermark
73-86 square body 5 lugs will fit just fine. Plentiful and pretty cheap
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 03-17-2019, 07:20 PM   #5
Ol Blue K20
They only fit half tons. The question was originally for 3/4 ton eight lug...
Dale
Old 03-17-2019, 07:29 PM   #6
bmxbang
Any insight on this? I'm no wiz when it comes to wheels but this makes it seem like they have the same hub size?
Old 03-17-2019, 07:34 PM   #7
rockyrivermark
Oops. Sorry.
My build page
Old 03-17-2019, 07:42 PM   #8
bmxbang
Im looking for 5x5 1/2 ton to my knowledge. I defiantly don't have eight lug
Old 03-17-2019, 07:44 PM   #9
Ol Blue K20
Oops. Sorry.
No need to be sorry. It was still good info for the five lug guys.
Dale
Old 03-17-2019, 07:52 PM   #10
Ol Blue K20
Oops, I need to apologize. I confused this thread for one asking about eight lug wheels. My bad and I'm sorry! Iguess today is feathers......
Dale
Old 03-17-2019, 08:14 PM   #11
Mike C
Mike C's Avatar
When GM switched to the 5 lug rim on the 2x4 trucks in '71 they reduced the pilot hole size. The 4x4 kept the old larger pilot. In '88 on the 1/2 ton 4x4 and light duty 6 lug 3/4 ton trucks they used the same small pilot hole as the 2x4 trucks.
So, the 6 lug 4x4 rims from '88 and up will NOT fit an earlier solid axle truck. But the 88 and up 5 on 5 2x4 rims should work just fine. And the 8 lug wheels keep the same pilot and lug pattern through 2010 I believe before it went metric.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-17-2019, 08:58 PM   #12
Ol Blue K20
I think you nailed it. The only problem I have spotted on the 80's rims on the earlier trucks is back spacing. The newer rims kinda look goofy on older trucks.
Dale
