04-01-2019, 01:57 PM | #1 |
cab corner replacement panel height
looking to find out if anyone sells cab corners the are at least 16" tall. my cab has a hole about 15" up from bottom of rocker -1969 k20
04-02-2019, 10:46 PM | #2 |
Re: cab corner replacement panel height
Not that I’ve seen. Is it not possible to just patch the hole?
04-03-2019, 07:56 AM | #3 |
I could patch t he hole, it is on a compound curve making patching difficult for a guy like me with limited skill. thanks for the reply
04-03-2019, 08:19 AM | #4 |
There is probably someone on the parts board that will sell you a 'cab cut'. Since that is not a common place for them to rust, you may just be able to get that area but will still need a cab corner if you have rust lower also.
