05-03-2016, 05:59 AM | #51 |
Re: 1972 Chevrolet Cheyenne K30 Extended Cab Dually REBUILD thread.
I should have said "shifting the front AXLE rearward is a good move" to allow more space in front of the engine- sorry. My truck should be the standard 127" WB- it's 126 1/2"
05-03-2016, 09:10 PM | #52 |
Looks like an awesome build. Love the 12v Cummins, can't wait to see it finished.
05-03-2016, 11:36 PM | #53 |
I'm in for this one!
05-04-2016, 06:06 PM | #54 |
6>8 Plugless........
Looking great! You might be able to use zero rate off set blocks to move the axle. It might raise the truck some but is a faster fix to move the front axle forward. Just an idea for you.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-04-2016, 06:57 PM | #55 | |
05-04-2016, 08:42 PM | #56 | |
Rottenwood Garage Member
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
05-09-2016, 09:44 PM | #57 |
We made some progress this weekend but no pictures. We got the body exactly where it needs to sit on the frame. Made the measurements and started to figure out the mounting needs. I need to get it locked down so I can move it out of the lift bay area. We removed the grille to cut holes in the radiator support for the inner cooler and removed the booster and master to swap with the hydroboost one off of the Dodge. We are also doinf some mechanical maintenance at thi point to include the KDP check, re seal the injector pump and new water pump.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 05-09-2016 at 09:53 PM. |
05-10-2016, 03:21 PM | #58 |
Very nice!
05-19-2016, 10:06 PM | #59 |
Any updates ?
05-22-2016, 08:59 AM | #60 |
We have been doing some of the little things and ordering parts. The cab mounting took a bit of time. It is bolted together and now is tack welded to the frame. The mechanical (engine) work that needed to be done should be completed this afternoon. The injector pump needed to be resealed at the back, the "killer dowel pin" needed to be checked and or done and we are putting a new water pump on it all while the grille is off the truck. By next weekend the bed should be mounted and I plan on moving the truck over to my 4 post lift where I can easily and safely work underneath that heavy beast alone. Next step is to cut the holes needed in the radiator support to accommodate the inner-cooler, get it mounted along with the AC condenser and then start to install and fabricate the brake booster and clutch slave from the Dodge. .
05-22-2016, 09:07 AM | #61 |
Looking good ,thanks for the update .
05-28-2016, 09:01 PM | #62 |
We had a full day. The body has been tightened down, the bed mounts were made, installed and tightened, we dropped it on the ground and fabbed up the inter-cooler. Tomorrow I will attach the condenser, work on the front bumper and possibly start working on the steering. Once the custom size radiator arrives (this week) i can get it installed and probably have it running again.
05-28-2016, 09:04 PM | #63 |
Time to hear it run!
05-29-2016, 05:59 PM | #64 |
AC condenser mocked up, Dodge master cylinder mocked up, clutch pedal assembly (Thanks UNCLE) altered and front bumper and brackets removed from old frame and staged for mock up tomorrow.
05-29-2016, 06:26 PM | #65 |
Looking great .
06-04-2016, 02:01 PM | #66 |
Today we had a light day. We got the old useless engine harness and computer to include cruise control removed, mocked up the front bumper, started working on the clutch master cylinder placement and finally moved the truck from the 2 post bay to the 4 post bay where I will be a little more comfortable working under it while in the air if I am in the shop by myself.
06-04-2016, 03:34 PM | #67 |
Looking good ,you have one heck of a shop.
06-04-2016, 08:19 PM | #68 |
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
06-04-2016, 09:16 PM | #69 |
Looks good. Is the tennis ball in the tractor tread for more traction
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
06-04-2016, 11:14 PM | #70 |
No, proof I have a black Lab.
06-04-2016, 11:15 PM | #71 |
Thanks!, Its a lifestyle around here!
06-05-2016, 11:57 PM | #72 |
Nice work on the truck! I dig your shop as well!
06-06-2016, 12:15 AM | #73 |
Thanks, Its a communal shop built by many with numerous Rottenwood Garage members hanging around at any time. I am just the fortunate one to have it in his back yard!. 100's of vehicles have passed through the doors in the last 15 years.
06-06-2016, 01:30 AM | #74 |
Subbed. That is some great work you guys have done, I remember seeing vids of the truck on youtube a while back
'71 K1500 Short-Wide '86 K30 C&C '89 Iroc-Z |
06-17-2016, 02:14 PM | #75 |
Brake master mocked and ready for final install, Clutch master mocked and ready for final install, pedal assembly mocked and ready for final install and we are working on radiator sizing to have it made.
We are going to firs and run it Saturday to make sure the pumpis sealed properly after our "o" ring replacement.
